Gas bottle compatibility
Discussion in 'Tech/Mech General' started by Mikejac, Jul 7, 2016.
  1. Mikejac
    Mikejac Funster
    Jul 7, 2016
    7
    France
    I have recently bought my first motorhome, a French Chausson 610 and have a bit of an issue concerning the gas supply. The Chausson has a gas bottle compartment "designed" to take a French 13 kg bottle, which attaches to the onboard regulator and hose via a simple screw thread connector.
    My problem is twofold. Firstly, it is difficult to get a 13 kg bottle into the compartment through the small access door and virtually impossible to lift it out whilst it still contains much gas. Hopefully when the gas is used up I'll be able to do so. Secondly, the compartment only holds the one bottle and so I have no spare for when the gas suddenly does run out.
    I would like to use smaller propane bottles so that they will fit easier and allow me to carry a spare in the garage, but the smaller bottles will not connect directly to the existing hose and all seem to require a push fit regulator. I understand you cannot have 2 regulators on the supply and so this would seem not to be possible, other than by removing the onboard reguator.
    Can anyone offer any advice on this. BTW, I am in France and so British bottles are not an option for me.
  2. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,542
    7,827
    Not an answer BUT did you not think about this before buying the motorhome ??
    Alternative.. Fit a re-fillable bottle that you will never have to lift in and out and gas is also cheaper..
    Wont overcome the fact you could run out though.... :(
  3. Kevan
    Kevan Funster Life Member
    Jan 18, 2014
    693
    583
    Herne Bay
    Hi i have a Rapido (french) I can get two 13 kg or bottles of that size in Spanish French or British, But have gone for Gaslow you can fill up anywhere without worrying about lugging heavy gas bottles in or out of a tight gas locker, all gas lockers seem to be two small.(y)
  4. SandraL
    SandraL Funster
    Jan 24, 2012
    287
    153
    Somerset
    French supermarkets sell "le cube" Its 6kg plastic propane cylinder. Its has a click on connector, i think its 27mm. From a caravan shop buy a high pressure adapter to fit it and either your old pigtail or a new one if required to connect the high pressure adapter to your wall mounted regulator. ( I have assumed you do have a wall mounted regulator)
  5. Mikejac
    Mikejac Funster
    Jul 7, 2016
    7
    France
    Thanks for your reply Sandra. I already have a couple of the le cube propane bottles, together with the appropriate clip on regulators. These are used in a caravan and I was hoping to use them in our new motorhome instead of the 13 kg bottle. I had made enquiries of a caravan accessory shop before posting my question here and they could not offer any ideas. Can you tell me what you mean by a high pressure adapter as I can't find any reference to these.
  6. maxi77
    maxi77 Funster
    Mar 20, 2013
    297
    164
    Kingdom of Fife
    Unless your motorhome is very old it will have a bulkhead regulator to reduce and control the pressure from the bottles. This will have a high pressure hose to connect the bottle to the regulator. A decent gas engineer should be able to supply the right one for your small bottles if the local caravan shop cannot. I have a gasit connector, and a UK propane, and a Butane bayonet so far
  7. SandraL
    SandraL Funster
    Jan 24, 2012
    287
    153
    Somerset
  8. Mikejac
    Mikejac Funster
    Jul 7, 2016
    7
    France
    Many thanks for that. I think I've now found what I need.
  9. Bart
    Bart Funster
    Jun 4, 2016
    1,711
    495
    N.Ireland
    +1 deffo ... must have bigger gas locker :D
  10. The Wino
    The Wino Funster
    Mar 23, 2012
    1,189
    2,190
    leicester
    Get a refiilable bottle we have a chausson 10 the locker is small but then you have a diesel heater so its only for water and cooking. The big advantage of refillable is you can top up at any time and not bother with a spare (and its cheap we recon on 50p a day for gas for cooking and hot water if off hook up)
    • Thanks Thanks x 1
    • Informative Informative x 1
