Gas Bottle adaptor (1 Viewer)
Apr 25, 2013
16
Bexhill-on-sea
Since 2006
Hi,
I am looking into the possibility of carrying a simple adopter to enable me to connect to a French "Le Cube" gas bottle instead of my Calor gas bottle (Male LH thread to clip on 27mm connector with right angle bend. This will ensure that I have an easy, cheap option if my gas runs out while in France.
This has probably been discussed many, many times before!
Have fun,
Bob
Feb 16, 2013
19,727
51,992
uttoxeter
ambulance conversion
50 years
Hi,
Have fun,
Bob
I have been looking for the same thing, without much success
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
you can get a 27mm clip on to the old uk butane thread . then adapt of that .BES do a gas cylinder adaptor from old uk butane to uk propane , catalogue number 21123 at 3.98 quid the 27mm adaptor is number 17917 at 9.62 . this should sort you i believe.
mangolover
4
Manchester & Thailand
A class RV
August 2011
I bought a 'Nomadic' BBQ - well a gas ring with a cast iron griddle/plache really - that plugs straight into Le Cube.
If a French Supermarket sells/exchanges Le Cube, they should stock the dedicated griddle. Also in the box is a regulator, presumably to use in-conjunction with another gas bottle.
mango
Nov 18, 2011
11,862
42,912
Planet Earth
A van
Over 25 year's
mango
could well take away the risk of blowing your shelf or sum other poore sole up :Eeek:
