fuses
Discussion in 'Tech/Mech General' started by chatteris, Oct 3, 2014.
  1. chatteris
    chatteris Funster
    Feb 15, 2014
    78
    64
    cambridgeshire
    citroen relay 2007 , are there fuses for the headlights? my drivers side low and high beam have stopped working,sidelight is ok though which I believe is through the canbus system. if there are fuses could someone tell me where to find them.
    thanks
  2. Jim
    Jim Ringleader
    Jul 19, 2007
    26,646
    78,856
    Sutton on Sea
  3. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,187
    15,162
    Leeds the one up North
    Fuse box in engine compartment F14 right main beam F15 left main beam
    Fuse box near driver dashboard F12 right dipped beam F13 left dipped beam and headlamp aiming device
    ALL 7.5 amp each
  4. movan
    movan Funster Life Member
    Dec 2, 2009
    13,951
    25,385
    Moving around
    Crumbs. Is there a way of knowing it is fuses when something goes wrong, please? I would have paid out for new bulbs ... and wasted my money again... :(
  5. Techno
    Jul 28, 2010
    14,187
    15,162
    No Joy but the first thing to check when anything stops working is it's fuse
    • Like it Like it x 1
  6. chatteris
    chatteris Funster
    Feb 15, 2014
    78
    64
    cambridgeshire
    thanks will look in morning, both bulbs were tested with multimeter
  7. chatteris
    chatteris Funster
    Feb 15, 2014
    78
    64
    cambridgeshire
    fuses were ok, bad connection on dip bulb and main,all working but aim adjuster is running all the time lights on so not quite sure whats going on so I am going to put a new headlight assembly in as I have had a few problems and it has a bit of corrosion where it had got water in it.hope that sorts it
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,089
    17,759
    YO11 2BD
    If you mean headlamp auto-levelling system is working constantly there will be position sensors somewhere on the front and rear suspension arms.
    The system senses the vehicle isnt level (via a preset reference point) by calculating the difference in the two sensor readings and adjusting accordingly.
    If you can find the sensors simply disconnect one......the self levelling wont work but it will confirm if the sensors are bad or not.
  9. Techno
    Jul 28, 2010
    14,187
    15,162
    No John we don't have auto levelling on X250 headlamps
    BTW headlights (new) can be found on ebay around £60 if you look
  10. Techno
    Jul 28, 2010
    14,187
    15,162
  11. chatteris
    chatteris Funster
    Feb 15, 2014
    78
    64
    cambridgeshire
    the plastic block on the dip bulb connecter look like it had been hot so took the the contacts out of block and put on bulb and it worked then, high beam bulb was a bit intermittent so new bulb put in and all working, can only assume adjuster motor running all the time made bulb connecter hot,presumably it takes its power from the bulb or I have a short
