Fuse for cigarette lighter - Fiat x 250 (1 Viewer)
Techno
Jul 28, 2010
15,475
20,752
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Depends on the year Phil
Varies between earlier drivers side fusebox and later engine bay fuse box
Early is fuse 44 20amp
Techno
Jul 28, 2010
15,475
20,752
May 2010
Later are fuses 14 and 15 in the engine bay 10 & 15 amp
So probably the 15amp!
DBK
17,968
47,804
Plympton, Devon
PVC, Murvi Morocco
I blew mine when we were in Spain earlier this year trying to use a cheap splitter to run two things at the same time, it was F15 and 15A. I didn't have a spare but F30 is the same size and as this was for mirror demisting, something I could happily do without, I just swapped them.
The cheap splitter went in the bin!
Oct 2, 2014
575
1,722
West Yorkshire
Rapido 866f
Since 2014
I think the fuse is in the fuse box in the cab. No need to lift the bonnet you could do it now between sips of wine!
Southampton
522
318
Hampshire
Since 2009
I blew mine on a 2012 Fiat and it was under the bonnet. Same scenario as DBK, using a cheap splitter.
DBK
17,968
47,804
Plympton, Devon
PVC, Murvi Morocco
You will need a cross point screwdriver to open the fuse box. It is on the right under the bonnet. And some thin nosed pliers to get the fuse out unless you have very strong fingers. They are tiny little things.
Sep 23, 2013
2,579
8,603
Lincs
Globecar Campscout
The 2013 ones are under the bonnet & the manual has the 2 socket fuses listed the wrong way round. Or you could say that the guys on the line wired them the wrong way round, but at least they did put the right fuse in each one for the socket they had wired them to.
Don't know if they are all like that, but I know mine isn't the only one.
PhilandMena
Feb 9, 2008
8,924
18,663
Corby, Northants
Coach Built
Fuse 44 in drivers compartment. Book say's 20 AMP but it had a 15 AMP one in so changed like for like. Now back in business again. I have a 3 way splitter that I connect to the gigarette lighter. The small spring which keeps the fuse in place and in contact with the base of the cigarette lighter had slipped down and made contact with one of the side arms resulting in a short. I have purchased a replacement but should have done the simple repair in the first place. Never mind, I now have a spare.
Thank's again to one and all. This is why we are the top forum.
