- Feb 24, 2013
- 13,083
- 101,447
- Hymer S800
- not long enough
I am currently on the CC site at Grantown on Spey, at 08:00 this morning it was -9C it is now -10C
Everything was fine till I went to the loo, internal temperature quite happily sitting just above 20c, it dipped a bit when I turned heating off to boil kettle
But I have no flush water, mine is fed directly off the cold storage tank
So been out to check, we have a standard Thetford type door to access the toilet mechanism, cant believe how warm it is in there, hot water pipes from Alde run through the compartment, so no idea where it is frozen, although I presume it is
I am not too sure where the pump is, loks like it might be in this compartment, but this is a problem of being on your own, cant press button and be outside to listen.
Not forecast to get much warmer, but have simple solution, that has in turn highlighted something
Sink in loo is working fine on hot and cold, so used coffee mug to fill loo for flushing (we have a macerator not a slide valve, so it needs water) filled to level we normally would, takes 4 mugs, no wonder we have to empty the loo so often when away together
Have to hope that when it thaws no harm is done
