Fully synthetic oil
Discussion in 'Motorhome Chat' started by Road Runner, Mar 21, 2012.
  1. Road Runner
    Road Runner Read Only Funster
    Jul 26, 2007
    14,196
    1,459
    Europe
    Just been to the expence of having fully synthetic oil change in my van to hear some guy serioiusly telling me it's not good in the 2500 TD fiat engine :Eeek:
    I sure he's MAD but please confirm I am right :pray:
  2. Dereckerick
    Dereckerick
    Jul 14, 2009
    237
    147
    Merseyside
    I used to use fully synthestic Castrol R 2 stroke oil in the race bikes, synthetic oil in a not so high spec engine would seem a bit OTT.
    I reserve the right to be wrong at any point:thumb:
    • Like Like x 1
  3. Terry
    Terry Funster
    Dec 27, 2007
    10,729
    6,234
    South yorks
    Here you go John
    Fully Synthetic Characteristics
    0W-30
    0W-40
    5W-40 Fuel economy savings
    Enhances engine performance and power
    Ensures engine is protected from wear and deposit build-up
    Ensures good cold starting and quick circulation in freezing temperatures
    Gets to moving parts of the engine quickly
    Semi-synthetic Characteristics
    5W-30
    10W-40
    15W-40 Better protection
    Good protection within the first 10 minutes after starting out
    Roughly three times better at reducing engine wear
    Increased oil change intervals - don't need to change it quite so often
    Mineral Characteristics
    10W-40
    15W-40 Basic protection for a variety of engines
    Oil needs to be changed more often
    Read more: http://www.carbibles.com/engineoil_bible.html#ixzz1plqzTU9z
    terry
    • Like Like x 1
  4. ronecc
    ronecc Read Only Funster
    Mar 21, 2012
    Hellifield, N. yorks
    Not sure synthetic oil can be bad for your engine, but check this site, it will give you all the advantages over mineral oil.
    http://www.opieoils.co.uk/pdfs/tech-articles/The-Advantages-of-Synthetic-Oils.pdf
    • Like Like x 1
  5. alfandM
    alfandM Funster
    Mar 12, 2012
    1,028
    1,034
    sweden
    sinthetic oils
    HI, there's no problems useing fully in your van, the only problems is you won't be able to go back to semi or normal diesel oil, unless you do a Engine flush, i always use semi in our's then if you can't get fully or semi you can use normal to top up, hope this answears your Q, Cheers Alf:thumb:.
    • Like Like x 1
  6. wivvy's dad
    wivvy's dad Read Only Funster
    Jun 22, 2010
    3,218
    1,807
    48.066895,12.862673
    Does the synthetic Castrol R smell the same?
    • Like Like x 1
  7. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,685
    5,834
    Mansfield,Notts
    To keep this simple
    There are basically only two types of oil
    1.MINERAL OIL (The old fashioned stuff)
    2. Fully synthetic oil (Man made superior product)
    So where does Semi Synthetic oil come into the equation
    Simple
    Its a 70%/30% mix of the two:Doh:
    so yes you can mix any and all oils if you want to,you will simply dilute the fully synths qualities
    No need to flush any engine at all when swapping from one to the other just change oil and filter as usual
    it is recommended to flush older engines prior to going simi or fully synth just to get rid of te crap left behind from the old minerals
    Geo
    • Like Like x 5
  8. wivvy's dad
    Jun 22, 2010
    3,218
    1,807
    48.066895,12.862673
    I love it when experts come along................:thumb:
    • Like Like x 3
  9. Dereckerick
    Dereckerick
    Jul 14, 2009
    237
    147
    Merseyside
    Smells fantastic!
  10. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    hi John.
    i do remember a post on here a few weeks ago about someone whom had changed to synthetic oil and found they had problems with leaks from the oil seals so went back to the old stuff and the problems disappeared.
    i think that was a 2.5 ducato as it also stated that fiat had changed the handbook and it now said some different oil to the previous book.
    so if thats the case just get someone to check for you that there are no leaks and all should be ok if it leaks then change back to the stuff you had before.
    • Like Like x 2
  11. 656
    656 Read Only Funster
    Jul 30, 2007
    1,150
    291
    The universe
    I use fully synthetic in my 06 2.3, in Edds 01 307 and in my 02 Smarty. All run very nicely.
    • Like Like x 1
  12. ciderman
    ciderman Funster
    Jul 2, 2011
    359
    409
    derbyshire
    semi gives you the same protection and as long as you change your oil every year it will save you money the detergents in full can be quite agressive and not good on a old style engine as the clearances can be a bit bigger than a modern tight engine :thumb:
    • Like Like x 1
  13. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,954
    2,750
    Englishman in Mid Wales
    No no its terrible stuff, truly awful, just give it to me to get rid for you, and you get yourself some cheap old oil:BigGrin::BigGrin:
    • Like Like x 2
  14. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,157
    8,069
    DERBYSHIRE
    John we had this the other day on here please see my post
    http://www.motorhomefun.co.uk/tech-mech-general/47094-engine-oil-2.html#post564954
    I would say its more important to get the grade right not to thin in an older design engine as posted in the other forum by Nick I think your van should be 15w40 semi synthetic NOT 10w40 as it would seem to cause long term problems with leaks if you use a thinner grade
    • Like Like x 2
  15. Hycon
    Hycon Read Only Funster
    Oct 6, 2008
    91
    16
    N.E Lincolnshire
    15w 40w recomended for my 1994 2.5 D hymer .Change it every year.I don't think synthetics were readily availible when it was made.
    • Like Like x 1
  16. Road Runner
    Jul 26, 2007
    14,196
    1,459
    Europe
    Me too!:thumb:
  17. jhorsf
    May 15, 2009
    9,157
    8,069
    DERBYSHIRE
    What grade did you use John?
  18. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,258
    5,239
    East Sussex 01-580-881288
    Yep and theres quite a few knowledgable experts on Fun unlike some other place
    Peter
    • Like Like x 1
  19. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,182
    14,954
    Leeds the one up North
    All base vehicle manufacturers handbooks offer a range of recommended grades of oil dependent on driving conditions and service intervals. I always use the best as it is cheap if you buy carefully and NOT from dealerships.
    I can change my oil and filter for £30 and do it every 10,000miles or less if a nice day crops up for getting under when I'm not busy
  20. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,583
    22,481
    Narrfoook
    There are def. certain engines that do not benefit.. Anyone who has ever owned a Blackbird for instance will tell you straight away that using fully synth is a massive no no..
    Causes some really weird problems including frothing and often an early bath for the CCT
    This is not hearsay or a maybe, its a reported ( repeatedly ) fact.. Folk who did not believe and tried fully synth almost always returned very quickly to either dinosaur oil of semi synth
    As to why .. I have absolutely no idea... After working exclusively on the bikes for 12 years and being involved to a certain extent with the Rand D dept in Düsseldorf I STILL have no idea !
