Full on heating! (1 Viewer)
Aug 29, 2013
143
114
Spain
A Class N & B Flair
Since 2014
We have a Le Voyageur LVX 850, with Alde heating. The system is definitely off, but the radiator besides the drivers seat, and the rad behind the travelling seat are red hot whenever we are moving. Not so good as we are in Spain at present!
I suspect that there is a valve somewhere on the engine to control water supply to these radiators, but I can't find it! The chassis is a Mercedes sprinter, with a 3 ltr auto engine. It will be 3 years old in November.
Any ideas good folk!
Ainsley
makems
3,438
27,692
Ingleby Barwick,,Teesside
Sadly had to give up
We have the Alde system on our Burstner. It has a heat exchanger which will heat the water and radiators when travelling.
On our van there is an illuminated switch behind the passenger seat. There is also a tap type vAlve In One of the outside lockers which has to be open for the system to work.
Your layout is bound to be different but I would imagine you will be looking for the same type of controls.
Feb 24, 2013
13,051
101,381
Bolsover, Derbyshire
Hymer S800
not long enough
We have Alde and Mercedes, put still no doubt different again to yours
We have a dash switch to left of steering wheel, looks more like a heated rear window switch, but this seems to warm our front bits up from the engine
Probably not a lot of help sorry
flyboyprowler
Aug 29, 2013
143
114
Spain
A Class N & B Flair
Since 2014
Thanks for the input. My next visit will be to Mercedes commercials, to see if they have an answer!
Snowbird
11,818
22,345
Liverpool.
Fifth wheel.
Since 11-05-2000
On my RMB there is a heat exchanger in a small cupboard on the passenger side. There is a tap on this to switch the flow of engine water on and off. There is also a dash switch to engage the small pump that circulates the engine water around the heat exchanger.
