Fuel
Discussion in 'Tech/Mech General' started by laser101uk, May 28, 2014.
  1. laser101uk
    laser101uk Funster
    Jun 6, 2012
    335
    847
    Basingstoke
    It's been suggested to me that every now and again its worth filling up with a premium diesel. Does this really make a difference?
    I always fill up at Sainsburys and supermarkets when in France, always using the cheapest. I don't mind spoiling the old girl now and again but only if its going to improve performance ;)
    cheers Steve
  2. daisy mae
    daisy mae Read Only Funster
    Mar 12, 2013
    676
    596
    Leicestershire
    I always use BP have noticed a big difference, smoother running, more miles per gallon, that is legit, done on computer, I have a good engine VW and want to keep it that way, never use supermarket fuel, it is only a small amount of difference on a full tank, I wait until the gauge shows 3/4 full and just top up, I was recommended to use this fuel by VW mechanic, and for me it is better.
    • Like Like x 1
  3. Melchior
    Melchior Read Only Funster
    Jun 26, 2013
    137
    80
    Amstelveen, Netherlands
    Modern turbocharged common rail diesel engines probably benefit from it. Older mechanical pump turbo and n/a engines - I'm not so sure at all. Ours is not common rail (Fiat 2.8 i.d. TD) and I have accidentally filled it with the fancy stuff and noticed no difference at all.
  4. Geordies
    Geordies Funster
    May 29, 2013
    953
    2,184
    Tyneside
    Think it was Quintin Wilson who recommended putting ordinary diesel in, then every 5ish tankfuls put the high performance stuff in as this (he says) has added cleaning additives and nice things for the engine.
  5. JonMac46
    JonMac46 Read Only Funster
    Jan 19, 2014
    36
    15
    Limerick, Ireland
    I used the "good" stuff when in Spain last winter and I thought she ran better. 1999 2.8idTD.
  6. DuxDeluxe
    DuxDeluxe Funster Life Member
    Jul 10, 2008
    9,423
    25,444
    Planet Zog
    Horses for courses really. I ran my 3 litre multijet on premium stuff because the overall cost difference was not much and there was an increase in economy, but it was a remapped engine. Basically it will not do any harm and there is quite a bit of anecdotal evidence to suggest it runs better due to the cleaning additives, but it is highly subjective. Once every few tanks seems ok - but I would point out that these engines are designed to run on the basic bog standard EN590 fuel that supermarkets and branded fuel stations all sell
  7. 1_man_and_his_dob(lo)
    1_man_and_his_dob(lo) Funster
    Feb 4, 2010
    2,264
    1,521
    Mid. Glamorgan, S. Wales
    I seem to be 50/50 between supermarket and BP/Shell/etc. fuel with my little Fiat Doblo Multijet diesel, following the opinion on here and elsewhere that it's worth visiting the latter for the additives.
    Having said that...with my old indirect-injection diesel Citroen AX I did > 330K miles using supermarket fuel pretty much all the time. Always did > 70 MPG. I reckon the engine would have still been running long after everything else had worn out if I'd kept it.
    Never used premium. All of mine have effectively been car engines though, not van.
    Edit: ooops....the OP was about premium vs. standard fuel, not supermarket vs. BP/Shell/etc. Sorry.
  8. johnp10
    johnp10 Funster
    Oct 12, 2009
    7,638
    14,305
    North Lincolnshire
    Fuel produced to a given standard is the same, no matter what the retailer calls it.
    As already mentioned, the EN number is the same.
    It's not unusual to fill a tank at a refinery preceded by a tank from a fuel Company, then followed by one for Morrisons.
    All the same product code, from the same silo.
    Same stuff, marketed differently at different prices.
    I use Morrisons fuel for my car (petrol), lawn mower (petrol) and the MH (Diesel).
    On the odd occasion when I've been faced with using "premium" fuel at an enhanced price I've found no difference in MPG or performance generally.
    Don't waste your money.
    Fuel is fuel.
    • Like Like x 2
  9. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,903
    17,577
    YO11 2BD
    if your engine is designed to use premium fuel (cetane rating of 55 rather than 48 for regular diesel) then it will say so in the base vehicles owners handbook.
    If it doesnt, then stick regular diesel in and save a few bob.
    • Like Like x 2
  10. Mike B
    Mike B Funster
    Jan 16, 2014
    794
    2,290
    Harleston, Norfolk
    We've got the best of both worlds; a Shell garage opposite a Tesco supermarket. The Shell garage is force to match the Tesco's prices. :Smile:
  11. magicsurfbus
    magicsurfbus Funster
    Oct 11, 2010
    3,717
    8,804
    NW England
    I buy standard fuel for MH and car, then once a year put some BG244 (diesel) or BG44K (unleaded) fuel additive in the tank to give the system a clean out. That definitely makes a difference to performance but it fades after a few thousand miles as the system gets gunked up again. With the MH it's worth putting it in the tank over winter when it's doing less miles so it's all clean and set up for the first long trip of the Spring.
    Chances are your garage uses a similar product during the annual service anyway.
    • Like Like x 1
