Fuel in France (1 Viewer)
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Article on BBC news this morning says to be very careful re the fuel you put in your vehicle as the "green" stuff they are selling will damage your engine? Anyone know any more? :Eeek:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Are you talking Biodiesel ???
Plenty of normal make-an-arab-rich diesel.
Munchie
Munchie
8,921
12,581
Camping Les Vigeres
Font Vendôme
Since 2004
Don't know just caught the tail end of the report but apparently people are buying it in error and damaging engines. Report said several people caught out leading to expensive recovery and engine damage. They did say cars. :cry:
weymard
249
CHERBOURG NORMANDY
US TRUCK CAMPER
:wub: Bio diesel do not exist in France ! May be you speak about E10 ?? for use it your car is necessary be constructed after 2000 (according manufacturer, in reality all cars after 1996 can run work it), and if you find more than 10 pumps with E10 phone to me :ROFLMAO::ROFLMAO::ROFLMAO:
Apr 29, 2009
2,320
1,991
West Yorkshire...Halifax
Vanless....BUT....!!!!
Apparently it's for petrol engine vehicles so most of us motorhomers SHOULD be OK!! unless you want to try petrol in a diesel engine ....not recommended!!:Doh:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
nothing wrong with sticking a gallon or so of petrol in your diesel tank.cleans it up nicely n helps when you have smoke test. good in winter if your going some where cold . best not fill it up though .
weymard
249
CHERBOURG NORMANDY
US TRUCK CAMPER
:thumb: Your are right, it clean the injectors :thumb:
Apr 29, 2009
2,320
1,991
I always thought that kerosene/parrafin did a better job, thats what we used in Germany when it was a bit chilly!!
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
think that works anytime. even heard of some using veg oil .we wouldnt do that would we.
scotjimland
2,246
9,758
A Woosh bang
Green Petrol
More info on the Green Petrol
The petrol called '95-E10' is a mixture of regular unleaded fuel and ethanol. It is suitable for new cars but can damage vehicles registered before the year 2000, motoring bodies have warned.
Full Story
weymard
249
CHERBOURG NORMANDY
US TRUCK CAMPER
:Angry: it is a motorized lie of the constructors. I rolled jaguar with a xj40 of 1995 during 50 000 km with E85 (85 % of ethanol!) without any breakdown!
Logical, they want to sell theirs new engine with "specificities bio-ethanol "! they lie !
D
david1234
you are right on older engines, i wouldn't try it on a common rail engine though? also petrol burns the plastic, rubber, filters 0 rings etc in the pump, there,s over 3000 psi in the rail and the way the injectors spray is critical, it will also blow your arm of if you try opening an injetor pipe when running to check its feeding fuel.:Eeek:
oldun
747
162
St Neots
VW Campervan
Since 2001
Ethanol has less energy than petrol so it is reckoned that an increase in fuel of 3% may occur with 10% ethanol (SP95 E10).
Ethanol removes gum deposits so the crud floating around the system may block filters.
Ethanol is hygroscopic, i.e it absorbs water and this, due to other substances in the fuel, can make it acidic. Damage to "rubber" seals has been reported and fuel stored long time may cause corrosion to the fuel tank.
It is reckoned that a 10% mix has little effect on modern (!) engines.
Link Removed
