Frozen screen on "Chinese" SatNav (1 Viewer)
Oct 8, 2014
1,614
2,948
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
The screen has frozen on my satnav. No response to tapping icons. Tried turning off & on, but no difference. Has this happened to anyone else?
irnbru
13,503
31,101
Glasgow
Benimar 264
11 yrs
Press the reset button. It's happened to loads of folk.
If that's your only fault your getting away light compared to others.
Mine works great apart from the odd reset. Just stick a pin in the reset hole on back.
Revolvor
Oct 8, 2014
1,614
2,948
Wiltshire
Thank you. I thought there should be a reset hole, but could only see the one by the USB socket ... which turns out to an LED. Unfortunately, pressing the reset button on the back has not helped. I think it's a bin job!
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
Leave it till it's battery goes completely flat, that will reset it, then recharge and away you go, I hope. :)
irnbru
13,503
31,101
Glasgow
Benimar 264
11 yrs
Make sure you hold the reset button in for at least 10 secs. It should work.
Revolvor
Oct 8, 2014
1,614
2,948
Wiltshire
No joy I'm afraid. Reset it a few times (20secs), but still the same.
irnbru
13,503
31,101
Glasgow
Benimar 264
11 yrs
Try what supermike suggested then and let battery run out or plug into laptop and see what happens. I wouldn't give up on it just yet.
There is a dedicated forum on FB for these so maybe worth an ask there.
Revolvor
Oct 8, 2014
1,614
2,948
Wiltshire
Yes thanks, I will try that. However after sitting in a drawer for months, the battery was flat when I took it out yesterday, and put it on charge. I will let it go flat again, and also try it connected to my PC. Will also try FB.
Thanks for your advice!
hilldweller
605
36,108
Macclesfield
Zilch Mk1
From Aug 2007
They never do because a monitoring circuit on the battery stops it killing itself. If you can remove the battery for a while that would be kinder to the system.
Feb 24, 2013
12,990
101,152
Bolsover, Derbyshire
Hymer S800
not long enough
Haven't you thrown it away yet o_O do you want a whip round for a new one? :)(y)
we bought some Tom Toms for work earlier this year, well under £100 with free map updates for life (y)
Revolvor
Oct 8, 2014
1,614
2,948
Wiltshire
Actually, I'm not that desperate to get it to work!!!
I have a good Garmin one that works fine - also with free map updates. I just liked having the ability to input vehicle dimensions. I have time on my hands, and have always liked the challenge of restoring a piece of kit that has failed.☺
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
I have had one some for over 5 years with no problems other than not being able to update the maps. My TomTom bricked itself in less time[/QUOTE]
