Frozen Locks
Discussion in 'Motorhome Chat' started by ROB1CHELSEA1, Jan 16, 2013.
  1. ROB1CHELSEA1
    ROB1CHELSEA1 Funster
    Sep 4, 2011
    2,481
    5,810
    Park Lane Bedhampton
    We've not used our motorhome yet since we bought it just before xmas, today Jane tells me she set up the bed about 16.00hrs to see how easy it was to set up, apparently quite easy and even easier to put away.
    All well and good:thumb:
    I get home an hour later and want to see this process in action BUT ALL THE LOCKS ARE FROZEN, keys go in but nothing doing (not central locking) Now my question is can i use de-icer in the locks or anything else to help open the doors? It would be a nightmare if we were away and couldn't get in:Rofl1::Doh::cry:
    ROB&JANE
  2. FM02MZO
    FM02MZO Funster
    Jun 22, 2012
    167
    28
    Castle Donington
    They should work via the remote control even if the locks are frozen, hold your key in the flame of a candle or simillar then try it in the lock.
  3. TheTwoOfUs
    TheTwoOfUs Funster
    Jul 24, 2009
    2,630
    7,333
    South Yorkshire
    You can buy lock de-icers. They are small aerosols with a nozzle which you put into the lock and squirt.
    • Like Like x 1
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,946
    17,609
    YO11 2BD
    no reason why not....the special lock de- icer sprays are only the same stuff you spray on your windsceen.
    once unfrozen you could try a little graphite grease, usually comes in little' puffer' bottles and should lubricate the lock barrel and tumblers amd slow down the freezing process.
    • Like Like x 1
  5. Stewart J
    Stewart J Funster
    Jul 1, 2010
    1,483
    1,333
    SW Northumberland
    WD40 spray onto both sides of key and work it in lock, will eventually free itt and WD in lock barrel will assist in preventing freeze up again. (Preferred method for padlocks out on ships deck when I was at sea):thumb:
  6. Barclaybasher
    Barclaybasher Funster
    Apr 13, 2012
    2,455
    7,285
    Derby
    Hair dryer ?:thumb:
  7. 1_man_and_his_dob(lo)
    1_man_and_his_dob(lo) Funster
    Feb 4, 2010
    2,266
    1,524
    Mid. Glamorgan, S. Wales
    I've used one of those in the past a few times to good effect, on an old Citroen AX lock. I did read/hear somewhere that you have to be careful that it doesn't blast all the lubrication out of the lock, i.e. spray grease it afterwards. Mind you, if it's frozen solid you probably need to do that anyway.
  8. teddybard
    teddybard Read Only Funster
    Aug 21, 2012
    7,610
    8,996
    warwickshire
    Get Jane to Growl at it
    she has a fiery breath:Rofl1:
    • Like Like x 1
  9. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Suck on it, usually cures lightly frozen locks - failing that, use a lighter and heat the key!
  10. Gromett
    Gromett Funster
    Feb 27, 2011
    8,087
    14,684
    UK
    NOOOO!!! you will end up with your lips frozen to the van door :Rofl1::Rofl1::Rofl1:
    I can just imagine the emergency services laughing their tits off as your other half tries to explain you weren't kissing the van....
    • Like Like x 2
