Front wheel bearing on boxer
Discussion in 'The Beginner' started by Mike foster, Aug 29, 2016.
  1. Mike foster
    Mike foster Funster
    Aug 21, 2016
    28
    4
    Lincoln
    just got the mot done on this Peugeot boxer m/h I have just purchased, one of the adviserys was a noisy front wheel bearing so I thought I would get it sorted, looked on Internet and the prices range from £20 to £80 with different makes, not wanting to put the wrong one on to have it fail down the road does anyone know what make to use.
    Regards Mike.
  2. ivorantony
    ivorantony Funster
    Jan 22, 2013
    514
    547
    London SE
  3. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,187
    15,162
    Leeds the one up North
    Do you know how to replace a bearing and have the necessary tools ?
  4. Melvin
    Melvin Funster
    Jan 22, 2016
    137
    120
    Norfolk
    I had continuing problems with nearside front bearings on my 05 plate boxer ,a so called Peugeot specialist fitted a cheap one that only lasted a couple of months,ended up getting a better quality one fitted that was better but even that got noisey after a few thousand miles.Never did get resolved before I px 'ed it.
  5. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,610
    3,424
    Telford, Shropshire
    Depending which model and what year you will need some either big or very big tools. You will NOT remove the old bearing with hammer and punch, the drive flange alone usually needs at least a ten tonne press to get it out ( I have a 30 tonne press and even that doesn't always do it). The actual bearing will vary in price depending on model and year, a year 2005 maxi for example will be dearer than a 1995 light chassis version. You will also need a BIG torque wrench, 2000-2007 maxi chassis for example requires the hub centre but to be tightened to 450Nm which is VFT!
    D.
    • Like it Like it x 3
    • Informative Informative x 3
  6. Mike foster
    Mike foster Funster
    Aug 21, 2016
    28
    4
    Lincoln
    My ideas was to remove the carrier and get an engineer to change the bearing, the van is a 1996 model
    • Informative Informative x 1
  7. dave newell lvs
    Oct 31, 2008
    2,610
    3,424
    Telford, Shropshire
    That could work but how will you undo and retighten the hub but? 400+Nm is very tight.
    D.
  8. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,787
    6,052
    Mansfield,Notts
    Well at least tell him how many grunts = 400+=Nm Dave
  9. Mike foster
    Mike foster Funster
    Aug 21, 2016
    28
    4
    Lincoln
    Not sure about that Dave I will have to look into that one but I do no a man with some very big tools, I should be able to hire the right tools for the job and hopefully save a pile of cash.
  10. lou020
    lou020 Funster
    Oct 5, 2010
    414
    257
    huddersfield
    I don't think it will have cassette bearings,1996 model will probably be a couple of taper roller bearings,dead easy to fit. my 1999 model had these.
  11. dave newell lvs
    Oct 31, 2008
    2,610
    3,424
    Telford, Shropshire
    Yes they will be separate bearings but the main problem will be getting the flange out as I said earlier. 400+Nm equates to 3 foot bar, four grunts and a hernia Geo.
    D.
  12. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,214
    3,625
    walthamstow east london
  13. Mike foster
    Mike foster Funster
    Aug 21, 2016
    28
    4
    Lincoln
    • Like it Like it x 1
