Fridges
Discussion in 'Tech/Mech General' started by Lord Mac, Nov 25, 2013.
  1. Lord Mac
    Lord Mac Funster
    Feb 5, 2013
    190
    232
    Devon
    Are you supposed to cover the fridge vents as the outside tempetature drops?
    Do you keep them covered when in use ?
    Where do you buy the covers or will cardboard do?
  2. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,758
    39,065
    "NO"...... don't cover when using...:Eeek:
    They are just for keeping the elements out during lay up period...
    Try not to direct a hose on them when washing.. or use the covers, but remember to take them off before flashing up... :thumb:
  3. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    depends on the type of covers you have. my understanding is that full covers are used as Old mo describes, but some covers are put in place to reduce the cold airflow over the fridge gear to prevent loss of efficiency.
    quote from my handbook:
    when the outdoor temp is below 8'c installthe thetford vent cover on the grills. the cover protects the fridge from excessively cold air. in no circumstance should they be used above 8'c,
    hope this help
    • Like Like x 1
  4. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,450
    12,616
    Bolsover, Derbyshire
    Does this only apply to gas operation, I have thought that when on hook up and the fridge set to electric only (not auto just in case electrics fail) I would be OK for the covers to be on
    Am I wrong again! :Doh:
    David
  5. jb0371
    jb0371 Funster
    Jul 8, 2011
    462
    402
    Norfolk
    we were told when the temp drops below 10c then put the fridge covers on, it does not impede air flow as there is enough holes to stop you gassing yorselves. My parents have a brand new van and they don thave covers at all.
    This is for fridges only. Dont cover over the heating vents unless you are storing your van for a while.
  6. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,685
    11,800
    Plympton, Devon
    We have a Dometic RM 5310 and the instructions very clearly state you use the covers when the ambient temperature falls below 10C - and they remain fitted when the 'fridge is being used.
    Other 'fridge installations may be different but ours sits behind one of the rear doors of the campervan and closing the external vents still leaves the condensor (the black finned bit) with plenty of air around it and there are also two small vents in the floor directly below the 'fridge.
    Of course, if closing the vents cuts off all air circulation then I guess you would need to remove the covers in use but then why bother to fit them at all except if you wanted to pressure wash the van? Your 'fridge at home isn't connected to the outside I suspect and works fine surrounded by normal room temperature.
    You can probably buy suitable covers for your model off flea-bay. I doubt you will do any harm to the 'fridge if you don't fit covers. We didn't last weekend ('cos I forgot) and it was below 10C all the time but I guess the internal temperature could get pretty low and things might start freezing not to mention a bit cold and draughty round the back of the unit.
  7. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    you need to look up the handbook on your model of appliance ( most are available somewhere on line ) mine is clear use below 8'c gas or electric not above 8'c in any circumstances.
    but my covers sit inside the vent and are shaped to allow reduced air flow not to completely block off air flow.
  8. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,809
    1,876
    Warwickshire
    The instruction book for our Electrolux (Dometic) fridge says that covers should be fitted when the temperature falls. I have never bothered using them (don't have any covers) and the fridge seems to work perfectly well without. I simply adjust the setting of the thermostat - turn it up when it's hot, only just on when it's very cold.
    If you want a set of covers, they are available at many online and bricks & mortar accessory dealers - try John Cross!
  9. Gromett
    Gromett Funster
    Feb 27, 2011
    7,998
    14,287
    UK
    Never bothered with them even when the temp dropped to -20C.
  10. maz
    maz Funster
    Jan 26, 2011
    2,528
    2,167
    Out there somewhere
    1. Yes - figure quoted is usually ambient temperature of 8oC or less.
    2. Yes - fridge works by using heat to evaporate the refrigerant. If air is too cold, the fridge will struggle to produce enough heat to do this.
    3. CAK Tanks often the cheapest source.
  11. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,171
    16,615
    Liverpool.
    I have em, but must admit to never using them. My beer is always cold, so the fridge must be doing what it was intended to do.
    • Like Like x 1
  12. Lord Mac
    Lord Mac Funster
    Feb 5, 2013
    190
    232
    Devon
    Thank you for the replies. I will look on-line for a set. I did not have an information book.
  13. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,046
    3,428
    walthamstow east london
    you must have the right ones ours are shaped so that the flue isnt covered this is the seperate area to the right of the top grill on our dometic
  14. cranky
    cranky Funster
    Oct 29, 2012
    399
    455
    essex
    Havn't heard that phrase since I was a junior stoker:BigGrin:
