Fridge (1 Viewer)
MattR
4,083
36,347
Beds
Panel van
Years
Not safe to have gas on when driving. No need with 12v and a safety risk in the event of a collision etc. (If you have an autoshut off device on your gas supply, it may be OK but I don't know how good they are).
Aug 6, 2013
11,931
16,514
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Apart from the above you will supply too much heat. You'll find your fridge will dislike that just as much as too little.
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
My gas is never off... I do have a 5g safety crash shut-off... But I don't run fridge on gas whilst driving...
As it would be pointless... If 12v available IMO
And a tad dodgy if stopping for fuel... That is why it takes 15mins to switch back to gas from 12v.. When you stop.... (AES fridge/freezer) To allow for diesel filling etc..
43,171
48,576
If you have an AES fridge (Automatic Energy Selection) you can't run two power sources at the same time.
If gas is present it will over-ride 12v.
Terry
11,898
8,913
Lincolnshire
Can't remember ;)
HI JUST HOW DO YOU RUN IT ON BOTH SOURCES ?A,E,S will only give one source and a manual turn will do the same YOU select gas or 12v
terry
Langtoftlad
8,824
148,261
Langtoft, South Lincs
WildAx Aurora FB [PVC]
Since 2015
I don't have AES in my old bus - but even with my jurassic fridge you can't run both, have to turn the knob to select 240v, 12v or gas.
funflair
19,156
29,796
Guisborough
MORELO palace
since 2012
On our AES 12 volt will override gas.
Martin
Jaws
23,814
71,771
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Martin
Same as ours.. In fact never had one that works the other way round..
Order of self selecting preference is
240v then gas
or
if the engine is started 12v to maintain what ever temperature the fridge / freezer is at
Jan 28, 2008
10,096
18,238
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
we run ours on both when travelling as we both usually forget to switch gas of weve had no problems but we do switch it of when refilling with gas
Fletton
1,531
2,501
Lincolnshire, UK
My guess - if you do that... It'll not be both.... Just one or tuther... :)
D
DL42846
In my van it all happens automatically. Gas when stationary,12 volt when on the move, and 240 volts when on electrical hook up. I don't have to touch anything other than switch it to auto.
