Fridge won't work on gas (1 Viewer)
ian63h
Bristol
Coach Built
I have a Dometic RM6505 fridge, which works on 12v and 230v, but not gas.I can hear it make a banging noise when you switch it on to gas, but nothing happens.
43,323
49,440
Hi Ian and welcome.
sounds like a partially blocked gas jet.
the 'banging' (more usually a loud POP) is the bit of gas that is getting through igniting then going out due to a weak mixture.
burner tubes are notorious for dropping little bits of debris etc onto the burner and blocking the jet.
ubuntu1
155
44
Derbyshire
PVC
since 2006
fridge not working on gas
Please don't mess with gas. Call out an engineer to do a fridge service for you. Take a look at the approved workshop web site and pick someone close to you.
I
ian63h
Bristol
Coach Built
It appears gas valve is not working, checked at PCB and is has got 12v going to it, how can i check this. many thanks for help.
