Fridge wont use any gas!
Discussion in 'Fridges & Ovens' started by Forester, Aug 10, 2016.
  1. Forester
    Forester Funster
    May 21, 2012
    159
    175
    forest of dean
    Whilst away a couple of weeks ago I noticed on our last day the fridge was not cooling as well. Our gas was getting low and for no real reason i put it down to that! Today I have fitted a new gas cylinder, cleaned and checked the position of the thermocouple cleaned the burner (new last year) Blown the chimney through all to no avail. Runs on mains electric fine ignites as soon as I press the knob on gas but flame goes out immeadiately I let the knob go and of course w go away on Friday! Any ideas of what I can try to fix it?
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,236
    15,222
    Leeds the one up North
    Is the thermocouple in the flame and glowing red
    • Like it Like it x 1
  3. Forester
    Forester Funster
    May 21, 2012
    159
    175
    forest of dean
    In the flame yes glowing red dont know should it?
  4. seanoo
    seanoo Funster
    Nov 14, 2009
    376
    229
    normandy
    have you checked the jet for crud. if you take it out dont stick anything in the aperture just blow it clear if blocked. if you dont have a clear stream of gas then the thermocouple cant get up to temperature.
  5. Techno
    Jul 28, 2010
    14,236
    15,222
    Yes it should be glowing red (y) but it could be the fault. I don't know how you test one other than replacing it.
  6. seanoo
    seanoo Funster
    Nov 14, 2009
    376
    229
    normandy
    it should be quite a bright red colour on the end. if not try to bend it carefullt into the flame more
  7. Forester
    Forester Funster
    May 21, 2012
    159
    175
    forest of dean
    jet seemed ok and it lights fine so assume all ok there thermocouple is in flame but will observe colour in the morning thanks all
  8. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,644
    3,477
    Telford, Shropshire
    Which model of fridge is it? Manual energy selection models from Dometic with a rotary selector switch can suffer from poor contact in the switch for gas operation (the tiny voltage from the thermocouple goes through contacts in that switch, the voltage from the thermocouple is so tiny that any additional resistance will cause the flame to fail when you release the valve. Try giving the energy selector switch a wiggle around the gas setting if it is of that type.
    D.
    • Informative Informative x 1
  9. Forester
    Forester Funster
    May 21, 2012
    159
    175
    forest of dean
    It's a Thetford Fridge can't see the tip of the thermocouple getting red but it's in the flame run out of ideas tried a couple of local places but no one available to look at it as they are all at Mslvern show !
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,382
    18,064
    YO11 2BD
    The T couple will glow red regardless of if its working or not.
    You are holding a piece of brass/copper in a flame so what else would you expect.
    If the burner lights and stays lit while holding in the button IT IS the Thermocouple at fault.
