Fridge wont light on gas
Discussion in 'Tech/Mech General' started by Hayleylulu, Jul 18, 2011.
  1. Hayleylulu
    Hayleylulu
    Feb 17, 2008
    5,391
    3,880
    Full timing in the van
    when the gas run out in the van i put new bottle on came to relight the fridge and it would not relight its a hymer 544 if anyone can help :Sad::Sad:
  2. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    It may take a while to bleed through, sometimes we have had them take a minute or so if they have run dry.
    You could have a bit of dirt from the bottom, but doubt it - probably just coming through the pipes slowly!
    Let it run, but don't get too silly or you will build up some excess gas and have a pop. Try lighting the cooker to help it along from the bottle.
  3. Tantalus
    Tantalus Funster
    Jul 24, 2009
    39
    4
    Summer in UK, then NZ
    There is just a possibility that you have pressed the control knob too hard while trying to light the flame. If it has worn a little it may not be actually releasing the thermo-couple.
    Try removing the knob and putting a very tiny piece of tissue paper down inside the knob so that it sits a fraction further out.
    You did turn the gas bottle on?
  4. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,755
    3,254
    Eastbourne East Sussex
    As above really, the fridge has a small gas jet so if it was right out and your pipes are full of air it will take quite a while to get through. I assume if you have Secumotion you have pressed the buttons.
  5. smudger
    smudger Funster
    Feb 3, 2008
    497
    703
    ireland
    when you say you put a new bottle of gas on....you did check if there was gas in this new bottle, and you did connect it , dident yoo:Laughing::Laughing::Laughing:
    • Like Like x 1
  6. Hayleylulu
    Hayleylulu
    Feb 17, 2008
    5,391
    3,880
    Yes i did and put a shilling in the meter there always one:Rofl1::Rofl1:
  7. rainbow chasers
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    another thing to check is if the light has lit, but the ignitor keeps clicking (depnds on fridge) this can be a pcb fault and is common fault on dometic (electrolux) rm models
  8. Hayleylulu
    Hayleylulu
    Feb 17, 2008
    5,391
    3,880
    Well still wont light dose any one know a Mobil fridge repair man or woman in the farnworth Bolton area
