Fridge uses lots of gas.. Why?
Discussion in 'Fridges & Ovens' started by Mattyjwr, Aug 8, 2016.
  1. Mattyjwr
    Mattyjwr Funster Life Member
    Aug 18, 2013
    1,940
    3,422
    Beds
    A friend has an old Hymer with a 3 way fridge about the size of an undercounter fridge.
    When on hookup, it cools well. When on gas, it uses gas very heavily (apparently, a bottle a day). Any idea why? When we have had high consumption, it was because the fridge was beneath a cupboard with lots of clothes in and it overheated. Their van's fridge just has a work top above it.
    I'll be sending them a link to the forum to look at joining but they are currently slumming it on a remote beach in N Spain without Internet.
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,224
    15,205
    Leeds the one up North
    faulty thermostat perhaps or a gas leak
    • Informative Informative x 1
  3. John Laidler
    John Laidler Funster
    Jan 9, 2013
    9,069
    12,424
    Plympton, Devon
    A bottle a day? Even if they are small bottles something is wrong. A new jet required I think would be a start.
  4. Mattyjwr
    Aug 18, 2013
    1,940
    3,422
    Beds
    Wouldn't a faulty thermostat give poor performance when on lecky too?
  5. Techno
    Jul 28, 2010
    14,224
    15,205
    Yes it would use more lecky
    • Like it Like it x 1
  6. Mattyjwr
    Aug 18, 2013
    1,940
    3,422
    Beds
    I'm not knowledgeable about gas fridges. Would a faulty jet allow lots of unused gas to escape?
  7. John Laidler
    Jan 9, 2013
    9,069
    12,424
    Plympton, Devon
    I'm certainly no expert but I know with just cooking and the fridge we get through around 3 or 4 kg of gas a week. I don't think even a faulty thermostat would consume a "bottle a day" as the flame is quite small and even burning twenty four hours a day it shouldn't empty a bottle. But what other uses of gas have they, how are they heating water? Something isn't right by a long way I think. A leak somewhere might be the most likely explanation.
  8. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    10,606
    12,025
    E Yorks
    Apart from anything else, tell them to STOP using the fridge on gas! If it is using, more likely losing (ie a leak) as much as that there is something seriously wrong! I suggest if they DO want to use it again they get their gas system tested to see if any leaks show up before they do.
    • Like it Like it x 6
  9. GeriatricWanderer
    GeriatricWanderer Funster
    Feb 1, 2015
    1,136
    4,172
    Back to a very damp and cold Essex :-(
    Forget about checking the fridge - get them to check their ventilation!
    • Like it Like it x 4
    • Useful Useful x 2
  10. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,957
    6,845
    West Sussex
    Just going to say the same, only way it could use that much would be a leak. The pipe from the burner & the control kob is steel they sometimes rust through you get pin holes on the bends.
  11. Mattyjwr
    Aug 18, 2013
    1,940
    3,422
    Beds
    She has a very sensitive nose for gas leaks and hasn't detected any smells. I will pass on the advice but judging by their past experiences of dealing with gas leaks in their previous home (new purchase, boiler faulty) I guess that a leak is less likely but am no expert and thank you for your replies.
    They don't use the fridge on gas but do on lecky.
  12. John Laidler
    Jan 9, 2013
    9,069
    12,424
    Plympton, Devon
    If they are not using it on gas then no panic, I thought they were. I suggest they get it checked as soon as they can and for the interim ensure the gas supply to the fridge is turned off.
  13. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,957
    6,845
    West Sussex
    If the fridge has been installed correctly and fully sealed from the inside of the van you probably wouldn't smell it inside, but you will feel the bang when it goes up.:)
    • Like it Like it x 3
  14. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,229
    14,218
    Bolsover, Derbyshire
    I have on occasion o_O forgotten to hook up to mains on return home, even after a month a 13kg cylinder is still going strong, I am with the others, something is seriously wrong, or they have been sold part filled bottles :)
    • Like it Like it x 2
  15. Mattyjwr
    Aug 18, 2013
    1,940
    3,422
    Beds
    I'll check if they have turned off the supply to the fridge, but if they haven't and they aren't using gas or losing it, does that give any other clues?
  16. Minxy Girl
    Aug 22, 2007
    10,606
    12,025
    E Yorks
    To me if they have the gas turned on (ie to use the hob) but are using the fridge only on electric, it would suggest that the pipework etc AFTER the control knob on the fridge onwards could be where the fault lies, eg leaking.
  17. Mattyjwr
    Aug 18, 2013
    1,940
    3,422
    Beds
    But if they have not turned off the gas to the fridge (and just don't light it) and do not lose gas, does that suggest any clues?
  18. John Laidler
    Jan 9, 2013
    9,069
    12,424
    Plympton, Devon
    Yes, as MG suggested, the fault is probably inside the fridge. If it isn't losing gas, and they are sure of that, then it should be safe but I am wary of suggesting anything is safe given the difficulty of diagnosing such a fault at distance. The balance of probabilities is it is probably safe, but 100% safe? I don't think anyone can say that without seeing the fridge.
  19. Minxy Girl
    Aug 22, 2007
    10,606
    12,025
    E Yorks
    As I've said the fault would have to be in the fridge 'gubbins' which are AFTER the control knob - in the 'off' position this would be prevent the gas supply from getting past it.
  20. Langtoftlad
    Langtoftlad Funster Life Member
    Apr 12, 2011
    2,055
    5,171
    Langtoft, South Lincs
    FFS - it's gas - get it properly checked out by someone qualified & experienced asap, rather than ask questions on here*
    *appreciate there are some very knowledgeable Funsters but without physically seeing the problem, its going to be guesswork.
    • Useful Useful x 1
