Fridge/servicing?
Discussion in 'Fridges & Ovens' started by Stacetop, Jun 29, 2015.
  1. Stacetop
    Stacetop Funster
    Aug 17, 2011
    196
    70
    We use a fridge on gas a lot but noticed the last few times that when the wind is blowing really strong onto the side of the van there is a gassy flue type smell which seems to be coming out next to the fridge above the smev oven which has an open ish metal vent above it. The smell does ago away when the wind dies down or fridge is turned off.
    Not sure if servicing will help in anyway? is this common
    We are in the North East can you recommend a good reasonably priced service person.
  2. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,157
    1,259
    Dronfield - Derbyshire
    What make of fridge is it?
  3. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,336
    5,592
    Guisborough
    There is a slightly gassy smell to the flue exhaust as you are burning gas, the fridge should be completely sealed so that nothing can blow into the van from outside (not many are) if the flue is also a bit sooty it certainly sounds like it needs the burner servicing/cleaning and the flue cleaning.
    I do my own so sorry cant recommend, but possibly Caterick Caravans, Kimberley Caravans at Darlington or Leisuretech North East at Stockton or mobile.
    Below is a recommendation from a funster @GJH
    http://www.motorhomefun.co.uk/forum/threads/leisure-tech-north-east.59919/
    Martin
  4. Stacetop
    Stacetop Funster
    Aug 17, 2011
    196
    70
    dometic rm?? small non auto igniting burner was cleaned about 2 years ago, nice blue flame
  5. Stealaway
    Stealaway Funster
    Jan 8, 2013
    1,157
    1,259
    It can get gunged up with rust particles dropping onto the burner jet. LPG is corrosive.
    Its quite easy to clean the burner, just don't poke the jet - they are about £15. Complete rip off - a 8 mm diameter piece of aluminium with a hole in it!
  6. Stacetop
    Stacetop Funster
    Aug 17, 2011
    196
    70
    I will try and get it serviced this week it might be that, most of our use is on gas!
  7. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,715
    10,145
    get it serviced but then try and seal the leaks at the top of the fridge using duct tape. access via the fridge vents
