Fridge replacement
Discussion in 'Motorhome Chat' started by Lindylooj, Aug 28, 2012.
  1. Lindylooj
    Lindylooj Read Only Funster
    Jun 24, 2011
    195
    81
    Weymouth, Dorset
    I was a good girl and cleaned out the fridge, even taking out the metal shelves, unfortunately hubbie decided in his wisdom to put them back for me and has put a 1/2 in hole in the fridge. I am presuming it is now defunct. Anyone know where we get a new one and who can fit them. :cry:
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,290
    16,962
    Liverpool.
    Where is the hole. If its only in the plastic, it can be repaired.
  3. Lindylooj
    Jun 24, 2011
    195
    81
    Weymouth, Dorset
    Hi yeh, he went to put shelf back in and it sprung back. I dont know about fridges but didnt they used to have chemicals in them that leaked if punctured? If repair can be carried out any idea what with. Thanks
  4. Snowbird
    Apr 24, 2009
    10,290
    16,962
    Liverpool.
    If its the condenser that's got the hole am afraid its a goner. If its just part of the plastic casing it can easily be repaired.
  5. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,286
    7,991
    West Norfolk
    It should only be a problem if you have damaged any of the pipework, burner or wiring at the back of the fridge.
    If you remove the external vents, you should be able to see if anything is damaged. Have you tried running the fridge? If it gets cold, then a patch over the hole in the plastic should be OK.
    You might be being over cautious!:thumb:
  6. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    If its just a hole in the inside case get a bit of white plastic and fix it over the hole with white silicone
  7. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,371
    1,456
    Suffolk
    Have you checked the price of a new 'fridge:Sad:????:Eeek::Eeek:
    Nigel & Pamala
    • Like it Like it x 1
