Fridge problems on mains
Discussion in 'Motorhome Chat' started by DanielFord, Feb 7, 2016.
  1. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,591
    2,784
    Surrey
    I think I know the answer, so really looking for a sanity check here.
    Just got to the van and hooked up, switched everything on, and all of a sudden, I hear the fridge igniting on gas! Odd so I check the panel and I have fault code 1. So I check the mains voltage, steady at 230v. Next pop off the covers and check voltage at the HC red and white wires, get 12.91 volts. In my mind, if I get a reading at the HC wires, this rules out the fuse. Am I correct? I am thinking that the heater element has had it and needs to be replaced.
    Thanks in advance.
  2. WillH
    WillH Funster
    Feb 9, 2008
    1,785
    1,497
    SW Scotland
    That was our experience with a Thetford fridge. Got a new element on Ebay though had to remove the fridge to fit it.
    • Thanks Thanks x 1
  3. icantremember
    icantremember Funster
    Sep 2, 2010
    5,451
    7,552
    Nr Watton in Norfolk
    That's the most likely and easily replaced but you may have to pull the fridge out from it's housing to get at it if not accessible from the exterior vents.
    • Thanks Thanks x 1
  4. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,623
    3,453
    Telford, Shropshire
    It always helps in these kind of threads to tell us make and model of fridge in question. It could be the heater element or it could be something else. You have established 12V DC power at the fridge but have you checked for 230V mains being present at the fridge? If 230V is present then it might be the heater element or it might be the main PCB at fault.
    D.
  5. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,591
    2,784
    Surrey
    You are quite right, I believe it is an N175, and I have checked for mains at the fridge, it is present and stable. The only real way to test the element really would be to test the resistance across the element, I am not going to pull the fridge out in this weather. If it ever stops raining, I will check it :D
    • Like it Like it x 1
  6. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,591
    2,784
    Surrey
    Finally stopped raining, so I checked the element resistance, and no surprise, it is an open circuit. Problem solved.
