Fridge on 12v
Discussion in 'Motorhome Chat' started by Feltwell, Aug 28, 2016.
  1. Feltwell
    Feltwell Funster
    Aug 27, 2014
    403
    382
    Shropshire
    I've noticed on longer drives, in fairly hot sunny weather ( 30 degrees or so) that by the end of the day the freezer contents are still frozen, but ice cream is very soft, and the fridge contents aren't as cold as usual.
    I know that 12v whilst driving isn't as effective for powering the fridge as 230v or gas is when you're parked up, but I thought the 12v setting would be enough to maintain the temperature.
    What do others find? Just trying to guage if I need to start fault finding the 12v system. Fridge is on the automatic setting, and flicks over to 12 v as soon as the engine is started with no problem, according to the display at least. Similarly, when stopped, the fridge does as it's supposed to on the auto setting and switches off for 15 minutes then switches to gas.
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,948
    17,616
    YO11 2BD
    Your fridge will only lower the temp by around 20°c below ambient temp so at 30°c it will attain around 10°c
    On 12v it wont be this efficient which is why your icecream is now yoghurt.
    • Like Like x 1
    • Useful Useful x 1
  3. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,140
    15,091
    Leeds the one up North
    My fridge works just as well on 12 volts
    as mains
    RMD8505
  4. Foghorn Leghorn
    Foghorn Leghorn Funster
    Oct 26, 2014
    219
    151
    Dumfries and Galloway
    Ours works fine on 12volt even when it was 90f near Montelimar it kept everything in the freezer solid , expected it to defrost but it was fine whilst on the move
  5. pappajohn
    Aug 26, 2007
    29,948
    17,616
    YO11 2BD
    The op's freezer is still frozen.....its the fridge not going low enough.
    Come to think of it......ice cream in the fridge !!!, no wonder its thawing.
    • Funny Funny x 1
  6. lorger
    lorger Funster
    Jul 11, 2008
    6,287
    7,743
    Dumfries
    if ours has been on gas or mains before travelling the 12v normally maintains the temp,
  7. scotjimland
    Jul 25, 2007
    28,934
    25,602
    First of all, lets put this myth to bed... There should be no difference in the cooling on 12vdc, 240vac or LPG .. the wattage, and therefore the cooling power of each energy supply is aprox. the same..
    Depending on fridge model, typically 120watt element on 12v and 125watt element for 240v
    Has it always been like this or is this a new problem. ?
    If it's always been like this then first thing I would check is the 12v wiring.. depending on the cable run it should be at least 2.5mm up to a 5mt run.. , on runs over 5 mts Dometic recommend 4mm ... At 120watts it's pulling 10Amps..
    Convertors don't always fit the correct size cable.. too thin a cable, and the volt drop will greatly affect the element wattage which reduces the cooling.
    (NB> That is cable cross section area in sq mm .. not cable diameter.. )
    If that's ok, you need to check that it has at least 12v when the engine is running.. this needs to be done at the back of the fridge on the 12v supply connections.... if below 12v then there may be a poor connection, or a problem with the split charge relay..
    (be mindful there are TWO 12v supplies.. one, a permanent supply for the electronics and interior light, the either only live when engine running, the one we are checking )
    If all that checks out ok.. then you need to look at how it's being used.. Overfilling will reduce the air flow around the shelves.. so products get warmer.. not unusual for people to pack it full before a journey.. There should be adequate space between the shelves and the evaporator to allow a good air circulation.
    Is the door seal damaged.. have you noticed the fins on the evaporator getting iced up ? If so that also reduces the cooling .. the ice acts as an insulator.. preventing proper cooling.
    If that's ok,.. when did you notice this problem .. was it climbing up and down hills.. out of level the fridge won't work properly.. but you would need to be doing that for long periods to have a detrimental effect..
    Operational Specs. from Dometic..
    Thermostatic control for 230-volt mains and gas operation
    Refrigerator +7°C, freezer compartment up to -12°C at ambient temperatures up to 32°C
    • Informative Informative x 8
    • Like Like x 3
    • Useful Useful x 1
  8. Shrimp64
    Shrimp64 Funster
    May 27, 2015
    554
    688
    Bedford
    I've always understood the fridge works on max whilst on 12V-no thermostat.
    Ours is working well now in France-day temp of 30° upwards but it still doesn't like ice creams unless they are flat on the freezer floor, ice cubes-no problem!
  9. Feltwell
    Feltwell Funster
    Aug 27, 2014
    403
    382
    Shropshire
    Eh? No, the ice cream is in the freezer, it's the whole fridge freezer that seemed a bit warm!
  10. scotjimland
    Jul 25, 2007
    28,934
    25,602
    Correct.. no stat on the 12vdc energy supply
    when we were in France this summer it was often 32c or more.. and had no trouble with fridge or keeping ice cream in the freezer..
  11. Feltwell
    Feltwell Funster
    Aug 27, 2014
    403
    382
    Shropshire
    Thank you scotjimland, very useful. I've definitely got the correct 12v supplies to the fridge, I checked those a few weeks ago when fitting fridge fans. The supply cable from the "engine" supply was fairly chunky, what exact size I'd need to check.
    Has it always been like this? Well,hard to tell, to date the van has been holidaying in the UK so sustained high temperatures outside weren't really a problem!
    I shall do some investigating if others find theirs are just as good on 12v. I presume the 12v heating element is a separate item to the 230v one? So it's possible that has gone.
    • Thanks Thanks x 1
  12. scotjimland
    Jul 25, 2007
    28,934
    25,602
    Yes.. two separate elements .. but they either work or don't work..
    if it has gone there would be no cooling, but it is quite possible , as you may not notice it's not working on short trips.. it may only become apparent on long journeys..
  13. John Laidler
    John Laidler Funster
    Jan 9, 2013
    8,766
    11,971
    Plympton, Devon
    • Useful Useful x 1
  14. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,414
    5,705
    St. Helens MERSEYSIDE
    Hi,DBK whilst your dog was chewing the thermometer was it a hot dog :):)
    • Funny Funny x 5
  15. JockandRita
    JockandRita Funster Life Member
    Aug 2, 2007
    5,861
    8,246
    Lincs/Cambs border
    That's the very same one we use to monitor the fridge temperature for storing Rita's meds, as the temperature has to be maintained between 3 and 10 degrees Celsius.
    Our Electrolux AES Fridge/Freezer unit works a treat off the 12v supply, but we've never relied upon 12v to bring the temperature down initially, only to maintain it.
    @Feltwell. Good luck sorting it out. (y)
    Cheers,
    Jock. :)
  16. matamoros
    matamoros Funster
    May 15, 2008
    2,419
    3,831
    Rochdale, Tavira, S. Brittany & Europe
    We had not used our fridge for a few weeks and tried an experiment as I had read that these fridges don't work as well on 12v.
    I switched the fridge on 12v, without prior cooling, at the beginning of an 8 hour journey from North of Inverness to Manchester, when we arrived the fridge had cooled to its normal operating temperature.
    • Like Like x 2
  17. SUGGY
    SUGGY Funster Life Member
    Nov 23, 2011
    930
    1,664
    scunthorpe
    a tip from another site was to put a freezer pack in the fridge to help maintain the coldness , we put one in the freezer section as well once we have made a bit of space ,
    we also run the fridge off the inverter , via solar and batteries , thus saving gas ,
    • Like Like x 1
  18. scotjimland
    Jul 25, 2007
    28,934
    25,602
    how does that work.. are they pre frozen before leaving home.. ? If so they will soon be at the fridge temperature, so a short term cooling effect and eventually just another product in the fridge.. using up valuable space..
    yes, you can run off your inverter to save gas.. only uses about 0.5A on 240v
    but you will need 10Amps from solar to do that without running the battery down.. , 125w / 12 = 10.4A
  19. SUGGY
    Nov 23, 2011
    930
    1,664
    scunthorpe
    Yes .
    260 w solar panels and 2 x125 amp batteries .
    Put fridge on inverter around 10 am then back on gas at around number 1 at 4 / 5 pm for the rest of the night .
    • Like Like x 4
  20. Feltwell
    Feltwell Funster
    Aug 27, 2014
    403
    382
    Shropshire
    Definitely something up with my fridge. On auto as usual, appeared to switch to 12v as usual when we started off today, but after a stop the fridge started buzzing an alarm as soon as the engine was started.
    So, for now, just running on gas - manual confirms I can drive with it on gas. Another thing to fix when I get home!
    And before anyone asks, yes I have got the regulator type that you can use safely whilst driving.
