Fridge not working on gas
Discussion in 'Fridges & Ovens' started by PhilandMena, Mar 17, 2016.
  1. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,906
    3,902
    Corby, Northants
    My Dometic 3 way fridge has suddenly stopped working on gas. The burner is going strong and we have no indication from the fridge warning lights that anything is wrong but the freezer has defrosted and the fridge up to 20 deg.
    Any ideas what could be wrong. Fairly sure it's an electronic issue and will try 240 volts next time we stop at campsite with lecce. We can survive without but would like to fix.
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,138
    15,084
    Leeds the one up North
    Mine still does that from day 6 onwards despite numerous repairs under warranty. I gave up in the end.
    Is it an 8 series?
    • Useful Useful x 1
  3. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    6,828
    13,503
    Bolsover, Derbyshire
    So if you switch it off and on again before the 6th day, or it auto selects 12V is it then OK again for another 5 days?
  4. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,112
    5,382
    Guisborough
    Hi Phil
    Have you checked that it is clear above the burner, sometimes scale drop down the chimney and diverts the heat away from the heat exchanger, give the flue a clean and check the burner.
    Martin
    • Thanks Thanks x 1
  5. Techno
    Jul 28, 2010
    14,138
    15,084
    Fine on mains and 12 volts but after day 6 gas is unreliable unless it is out of service for a while.
    I've had a new cooling unit and all circuit boards twice.
    Engineer fixed it temp last year by replacing the 8 series board for a 7 series and that cured it. Dometic won't accept that as a fix but won't acknowledge there's an issue with the 8 series board
    • Like Like x 1
    • Thanks Thanks x 1
  6. Techno
    Jul 28, 2010
    14,138
    15,084
    My 8 series AES bypassed with a 7 series MES
    • Informative Informative x 1
  7. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,906
    3,902
    Corby, Northants
    Not sure what series mine is, will have a look and let you know. It has been faultless for the last 5 years.
  8. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,906
    3,902
    Corby, Northants
    Have now cleaned flue with help from some fell Funsters and burner roaring like a good un. Will let you know if this solves problem. Thanks one and all for your helpful input.
    • Like Like x 3
  9. xsparks
    xsparks Funster
    Mar 11, 2013
    149
    73
    Gillingham
    Had a similar problem found a dead fly in the jet where it mixed the gas and air.
  10. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,906
    3,902
    Corby, Northants
    • Like Like x 3
  11. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    6,000
    11,428
    East Sussex
    Could you have got a brush up the flue from below or could you only gain access when the fridge was removed?
    Looking at the Dometic handbook they suggest servicing at least twice a year if running of gas
  12. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,906
    3,902
    Corby, Northants
    There is a baffle at the top of the flue that needs to be removed and cleaned. As things worked out I only needed to push the fridge 6 inches into the motorhome habitation area after disconnecting the services, so I could get access to the screw which is now back in place by two full turns, meaning I can remove it in future without having to move the fridge. This is the first time the flue has been cleaned and the fridge is 5 years old. 4 deg inside fridge this morning and all appears to be well.
    • Like Like x 2
  13. ukbill
    ukbill Funster
    Nov 3, 2011
    4,929
    4,882
    benidorm
    my thurmo fridge freezer has stopped working on mains and gas do i need a new 1?
  14. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,087
    2,927
    Kendal, Cumbria
    When did it last work on mains or gas :D2.
  15. Wagoneer
    Wagoneer Funster
    Jul 6, 2016
    190
    93
    Sussex
    @Techno - I see from your pic the plastic drain pipe from the fridge exits to near the bottom of the vent cover. Is that standard on series 8 fridges or your modification?
    My series 7 fridge drain pipe goes into a plastic container which sits on a hot recirculation pipe. The container is always overflowing so I need to divert the drain pipe. The route of the drain pipe shown in your pic would easily overcome my problem. Any comments?
  16. ukbill
    ukbill Funster
    Nov 3, 2011
    4,929
    4,882
    benidorm
    About 6 weeks,kept going ok then stopping
  17. dpsuk999
    dpsuk999 Funster
    Jun 6, 2012
    326
    298
    Leeds
    I have a 7 series and I just lengthened the pipe and exited it the same as @Techno. Here is a pic
    • Thanks Thanks x 1
