Fridge leisure or vehicle
Discussion in 'Tech/Mech General' started by Rooky Vanner, Aug 27, 2016.
  1. Rooky Vanner
    Rooky Vanner
    Mar 23, 2015
    80
    116
    North Nottinghamshire
    Morning all out there in the wisdom hall...
    Now
    When I put my fridge on battery, is it running off the vehicle or the leisure battery??
    Many thanks
    Andy,
    Currently enjoying the sun in Durness...
  2. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,362
    3,770
    Rural South West Wales.
    In ours, it's the vehicle battery.
  3. Rooky Vanner
    Rooky Vanner
    Mar 23, 2015
    80
    116
    Yes been reading posts which is what I should have done in the first place( but no one ever does) it seams it is van battery in ours. Seems daft really on no hook up sites where we spend most of our time, to use gas when sun is shining and we have 100w solar panel?
    Needs research I think but thanks for confirming my suspicions...
  4. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,362
    3,770
    Go easy with it's use because the fridge will flatten the vehicle battery really quickly resulting in the vehicle engine not starting :eek:
  5. Doctor Dave
    Doctor Dave Funster
    May 18, 2015
    299
    616
    Wiltshire
    When on 12 volts my fridge only runs when the engine is running - it is designed that way.
    Dave
    • Like it Like it x 1
  6. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    1,816
    3,470
    Cumbria
    When you say "on battery", do you mean when you have selected "12 volts" as the supply ? If this is the case, then the fridge is technically running off the alternator while the engine is running, switch off the engine and the fridge will stop working. Most vans have absorption type fridges which would soon flatten your battery if it was left to run on a battery alone, although some on here with plenty of solar and leisure battery capacity can adapt their system to use any "excess" solar power they are generating to supply their fridge.
    • Useful Useful x 1
  7. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,379
    3,154
    Kendal, Cumbria
    The fridge uses 100W. Your panel might turn out its 100W if tilted and turned continuously to face the sun in a cloudless sky. Given that none of those conditions will ever be met your leisure battery will be fully discharged within hours. There's a very good reason why the fridge is set-up to operate on 12v only when the engine is running.
  8. peterc10
    peterc10 Funster
    Jul 5, 2013
    4,033
    2,969
    Tunbridge Wells
    As others have said a 100W solar panel won't be able to run a 3 way fridge. And even if it did there would not be any power left to charge the batteries for the night.
  9. Rooky Vanner
    Rooky Vanner
    Mar 23, 2015
    80
    116
    Hmm.. It seemed like a good idea at the time but as you can tell I am no electrician, I am a gardener so each to his own. If you ever have trouble with your wallflowers I'm yer man.
    Thanks to all who contributed.
    • Funny Funny x 1
  10. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    Hi your fridge should/probably is wired to the LB not vehicle battery - the van will have a relay that turns on when engine is running supplying 12v to the fridge and usually L Battery both supplied via the engine/alternator When the engine is turned off the 12v is also turned off via the relay so your fridge should not be working on 12v without the engine running-
    terry
  11. Rooky Vanner
    Rooky Vanner
    Mar 23, 2015
    80
    116
    Thanks for that. Sat in Ullapool at the moment planning a Harris trip... Thanks to all
