fridge help and advice needed please (1 Viewer)
fabweb
25
we are in sadnaria at moment ...lovely site
only getting 4amp on plug in hence the fridge is not working
i have checked it with generator and it works fine on that, 12v and gas
so how can i bypass the plug in and stay plug in but use the gas ...we need and would rather use our own supply and have the fridge cold
thanks for you help
hymer 694
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Please correct me if I am wrong,, but are you saying the site electricis are not man enough to run your fridge?
If so, does`nt your fridge have separate switches to run it on 240v-12v or gas.
I am curious.
F
fabweb
25
yes you are right
i can find a switch to select what kind of power
its a hymer 694 1993 orginal fridge ...works great but on on plug in
we have had the same problem at other sites,
cheers
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
I have a friend with the same model, but a 1994,, if no one else comes up with a solution I could ask him if you like,, but I cannot get hold of him till this evening,, let me know.
scotjimland
2,312
9,984
A Woosh bang
You said it worked ok on the genny.. sorry, not disbelieving you but are you absolutely sure ?
A 4amp supply is more than adequate to run a fridge, the supply voltage may be low, it quite often is on Spanish sites, I've measured it and seen it as low as 200v, but the fridge will still work, albeit not as good..
If it's not working on the EHU on this site or on others I suspect there is a fault on the fridge on the 230v side of things.
I don't know how yours is connected, some have a socket at the back you could unplug or maybe it has an ~ MCB you could switch off ? .. failing that it could be physically disconnected .. if you do this ensure the EHU is unplugged and no one can plug it in while you are working on the fridge.. you should be able to gain access through the fridge outside vent cover.
hth
Jim
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
If you know were it is, or can find it by trial and error, pull the fuse for the fridge and it will than revert to gas on its own
Geo
