- Feb 18, 2009
- 574
- 250
- Malibu T410
- Since August 2008
Dometic Tower system on our Carthago- - had fume smells previously only when wind direction is blowing directly at/into fridge vents - at one time had both carbon monoxide alarms going off when van was all closed up and fridge on gas. At the top of the TEC tower inside the van there is a ventilation/air gap above the cooker and this is where the fumes blow in when its windy. Didn't have this gap on our last van with TEC tower.
Since then - had hab check done several months ago - fridge wasn't serviced but they checked with their machine & couldn't find anything wrong - of course not as no wind in their workshop.
Had fridge serviced locally before we came over to France - new burner fitted - and again everything checked out OK - and again - their workshop was surprisingly lacking in wind.
So how to solve the problem when we get back to the UK? thinking that there must be a problem with the seal behind the fridge - so to try and identify where the problem is - I was thinking to use a smoke bomb in lower compartment/grill - seal both of the grills and try and see where smoke is getting through? and seal with tape? Of course the only test will be when its windy
Any suggestions or experiences with this problem?
