Fridge/Freezer
Discussion in 'American RV's' started by long range, May 3, 2010.
  1. long range
    long range Read Only Funster
    Feb 25, 2009
    9
    Hi can anyone help with a problem we are having with our f/f, in our Vectra RV when we use it on gas after a while 5/10 min a light comes on saying check, we have looked thro' manual and done what it suggests and it seems fine for awhile.
    It works fine on electric. Someone said it may have an air lock? and to take it out + leave it on its side for 24 hrs? Bit unsure about that.:Eeek:
    It is a Norcold. Looked in back of RV magazine and found mobile maintenance but they dont seem to want to come and take a look. Any suggestions would be gratefully received.
    Thanks Gail
  2. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    Assuming all models respond the same .....look here
    http://bryantrv.com/docs2/docs/8682.pdf Page 5.4 refers to 12volt feed.
    It may be there's a volt drop or the battery is getting tired..
    Or a gas feed problem?
    "When the Burner does not ignite,
    or it ignites and goes out
    when the sparking stops, the
    Ignition Module will close the
    gas valve, turning off the gas
    supply to the Burner, and illuminate
    the red CHECK light."
  3. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,290
    16,961
    Liverpool.
    That used to be the case with the older Norcold fridge freezers,but it was when the gas was burning,but the fridge wasnt getting cold.
    I used to have to take mine out yearly and tip it on its left side overnight on my old Rockwood,got that used to doing it I could have it out and on the dinete in 15 mins.
    Its coused by not leveling up the RV and happens over a period of time.Many people think that if it dosent get cold its a scrapper,but have you seen the replacment cost???.
  4. damondunc
    damondunc Funster
    Aug 2, 2007
    101
    15
    near Lincoln
    norcold fridge
    what is the model number and serial number? you have various possibilities, the burner tube is full of rust from the chimney, the igniter module/control board and or the spark electrode are faulty, or depending on the model you may have a faulty control switch/cable. Don't bother taking the fridge out and laying on it's side, if the fridge is working ok on mains doing this will not achieve anything.
    Dunc.
  5. RVfulltimer
    RVfulltimer Read Only Funster
    Mar 15, 2008
    28
    Hello we have been having problems with our norcold f/f its thirteen years old and has been defrosting every other day tried all sorts but in the end swapped it for a domestic compressor type as the rv is sited full time and on ehu its no problem.
  6. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    940
    cheshire
    Yep someone did that with the first 5ver we bought and neglected to tell us, cost us a fortune buying a new unit, For them not a problem as they didnt do rallies/shows so always used ehu, we do both rallies and shows infact the 5ver i have now hasnt been used on ehu yet, but i have seen it plugged in and working when i bought it.
  7. 7149capricorn
    7149capricorn Read Only Funster
    Jun 19, 2008
    For what it's worth.......... have you checked the house batteries? Our fridge needs 12volts to work the control panel (as well as propane/AC) - working off propane you are presumably not connected to shore power so if you weren't getting 12 volts it would not work, whereas on shore power (or genny) the batteries will be being charged at the same time. I think.......!
