Fridge/freezer
Discussion in 'The Beginner' started by stringa, May 14, 2015.
  1. stringa
    stringa Funster
    Mar 26, 2015
    61
    133
    lincoln
    Nah then,
    Just collected my new to me MH, and booked a short trip to Woodhall spa.
    when do we switch on the fridge / freezer..ie when we get there or the night before, if its the night before is the power draining the battery.......and if its when we arrive it might take ages for the food/beers to chill..........Thanks for reading
  2. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    6,498
    6,481
    West Sussex
    If going in the morning turn it on night before, if leaving in the evening turn on in the morning, assuming it's a 3 way fridge either run it on gas (for best cooling) or mains, it will only run on 12 volt when the engine is running, one exception Hymer's if no other source of power they switch to the leisure battery and will flatten it in a few hours, I pulled the fuse on mine so it can't do it.
  3. scotjimland
    Jul 25, 2007
    28,940
    25,628
    Your fridge has three power sources.
    GAS.. for use on sites with No Ehu (electric hook up)
    230v Mains.. for use on sites with EHU .. and also on your drive
    12v DC for use when driving only
    So, plug your van into the mains and set your fridge to 230v .. if it's an 'Auto Power' select type it will do this automatically
    • Like it Like it x 1
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,115
    17,785
    YO11 2BD
    If you have no hookup at home/storage facility then switch to gas....or if its aes (auto select) it will switch automatically once the gas is turned on.
    Overnight it will use next to no gas....the burner flame is little more than a cigarette lighter flame.
    12v will not cool the fridge from ambient....it only maintains the current temperatute.
    to chill it faster, if you are taking any frozen food place it in the fridge when you set off....the food will slowly thaw but will cool the fridge pretty quick.
  5. stringa
    stringa Funster
    Mar 26, 2015
    61
    133
    lincoln
    not sure what you funsters mean........on the fridge it has a red and a green switch........which is which...... also today I bought a 25m cable but its only a male and female fitting which no doubt is for my hook up....should I have bought a different type cable and plug to run from my kitchen to my MH.........its a wayfarer by the way
  6. scotjimland
    Jul 25, 2007
    28,940
    25,628
    you bought correct .. to connect at home you need a mains adapter ..
    like this http://www.amazon.co.uk/Mains-Adapter-Plug-Caravan-Socket/dp/B004037LP0
    sorry, not familiar with your fridge knobs
  7. CWH
    CWH Funster Life Member
    Jan 29, 2014
    3,110
    13,567
    under a wand'rin' star
    The guys on here who know what they're talking about will need manufacturer/ name/ model etc of your fridge, also ideally photos.
  8. pappajohn
    Aug 26, 2007
    30,115
    17,785
    YO11 2BD
    Green is 230v (only on hookup), red is 12v (only with engine running)
    While driving, 12v should be on while 230v is off and gas off at bottle.
    On site, turn off 12v and turn on 230v (if hookup available) or turn on gas and use fridge gas controls to set temp and to ignite.
  9. scotjimland
    Jul 25, 2007
    28,940
    25,628
    Plenty to learn .. eh..
    I guess you could spend some of the w/e reading the motorhome manuals.. with a cool one of course
    have fun.. :)
  10. pappajohn
    Aug 26, 2007
    30,115
    17,785
    YO11 2BD
    In the absense of frozen food buy some cheap freezer packs from a pound shop, freeze at home and place in fridge.....does the same as frozen food but need storage space when not in use.
  11. old-mo
    old-mo Funster Extra Special Life Member
    Oct 16, 2008
    12,927
    40,039
    Remember if you are running on gas................ make sure you are level...
    To work properly and not end up with a soot ball in your chimney it has to be level... or within a very few degree`s.. of being level..
  12. stringa
    stringa Funster
    Mar 26, 2015
    61
    133
    lincoln
    Fellas......thanks for the info.........pappajohn thanks for that......seeing as our rose has only two mags to read.....she could maybe read the instructions........its not my cup of tea.........think I`ll be fishing....
  13. rosalan
    rosalan Funster
    Jul 12, 2013
    882
    760
    Beds
    If you can get yourself onto a Fun rally, there will be plenty of people willing and able to answer questions. We have all had to go through some form of learning process and the newer the van, the greater the learning curve.
