Fridge fixed... (1 Viewer)
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Despite a fan and other items to help the fridge work I finally fixed it.
Ice crystals in the fridge. You know you're jealous.
Sidney
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
Well 3-way fridges are not built in the same way as modern compressor fridges. The aluminium fins in the back of the fridge simply touch the refrigerant pipes (which absorb the heat) and these are built into the insulation. Like a rolling pin on a work surface the point of contact is quite small and this is made worse by too much foam insulation either partially covering the pipes or pushing the heat sink away from the pipes.
By liberally applying this compound the point of contact is larger so heat is more easily absorbed from the inside of the fridge.
Penny of tar..,
The compound isn't cheap so why would the manufacturer use more than absolutely necessary? So they just use a bit.
By taking the heat sink off (torx screw) you can put on a lot of compound and improve the performance.
Nov 3, 2013
3,161
9,259
Portugal
Fiat Ducato Auto Wildax
C/van since '73 .M/h.2009
Hi.
Will the new cry be.... "We was robbed,not.....GASSED,but we could not fend off the intruders,as we were in the first stages of........ Hypothermia."?
Tea Bag
