fridge fan needed???
Discussion in 'Tech/Mech General' started by jaygee, Jul 21, 2010.
  1. jaygee
    jaygee Funster
    Mar 21, 2009
    1,204
    748
    Harwich, Essex
    Our firdge struggled in the hot weather recently. Having looked online the common solution seems to be to fir a single or double fan near the vent to cool it. Has anyone done this? Can you recommend which fan to buy?
  2. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,336
    17,057
    Liverpool.
    Yes, Maplins will sell you a cheap fan,i used one from a computer and wired it direct to a small cheap solar panel on the roof.
    It only works when the sun is shining which is what you want.
    The whole setup cost about £20 and works perfectly.
  3. robinmclaren
    robinmclaren Read Only Funster
    Feb 23, 2009
    345
    32
    coventry , warwickshire
    yes pc cooling fan wired through thermostat from fridge power cable so always works when fridge on and temprature above 45 deg
    :thumb:
  4. scotjimland
    Jul 25, 2007
    29,041
    25,733
    Suffolk
    I used a pair of 12v computer fans and wired them via a small push switch to the 12v fridge supply .. I mounted inside the top vent using perforated ally strip.
    I had a plan to fit a small thermostat but in the end never bothered ..
    Have a look, there should be a top air flow deflector plate , (a curved piece of aluminium which helps air flow) ... some installers don't fit them, also make sure fans are exhausting ..
