Fridge Conundrumthe
Discussion in 'Motorhome Chat' started by Manxcat, Aug 26, 2016.
  1. Manxcat
    Manxcat Funster
    Jun 22, 2011
    112
    141
    Isle of Man
    We have a Globecar Campscout with a dometic fridge.
    At the moment the builders are working on the house so we had to find a temporary home for the van. It has ended up living n the builders yard.
    Anyway, we are plugged into the mains - whilst at the builders the fridge is not working, we pick up the van and it is warm and no ice!!! We have checked, the mains is definitely working and we can plug in and boil the kettle.
    Bring the van home, plug it in and ice is starting to form within an hour.
    Anyone here able to give a plausible explanation for why electricity 4 miles away is not as good as ours?
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,126
    17,793
    YO11 2BD
    Maybe just a glitch in the fridges control board.
  3. Langtoftlad
    Langtoftlad Funster Life Member
    Apr 12, 2011
    1,945
    4,975
    Langtoft, South Lincs
    Usually someone says "was it level?" when fridge issues are posted...
  4. Manxcat
    Manxcat Funster
    Jun 22, 2011
    112
    141
    Isle of Man
    Definitely level.
    I cant see how a control board can say to itself I am in a builders yard so I wont work. Great I am back at home so I can start working again!
  5. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,559
    2,566
    Trowbridge
    Is there any chance you plugged in to 110v supply? The fridge may be clever enough to spot that whereas the kettle wouldn't I guess?
  6. scotjimland
    Jul 25, 2007
    28,941
    25,637
    The yard supply voltage is probably low.. I've had this problem on busy Spanish sites .. it won't affect a kettle.. or anything with a heating element.. other than make them slower to heat.. but it will affect the fridge.. even though it has a heating element the electronics sense low voltage and shut off. Below 195Volts AC , it won't work..
    is it on an extra long extension cable .. or a long way from the main supply.. ?
    Not possible.. the Blue 16A 240v plug won't fit a Yellow 110v Socket
    • Informative Informative x 1
  7. Armytwowheels
    Armytwowheels Funster Life Member
    Aug 10, 2012
    4,182
    6,863
    Spain for the winter
    You say it was level but some modern fridges only have to be 3 degrees out to not work properly, e.g new Thetford. As @Jenben found out in Spain.
  8. Jenben
    Jenben Funster
    Oct 19, 2015
    512
    4,892
    Uk
    Yes we still owe you a digital thermometer @Armytwowheels and have a spare one with your name on it :) .
    • Like it Like it x 1
  9. Manxcat
    Manxcat Funster
    Jun 22, 2011
    112
    141
    Isle of Man
  10. pappajohn
    Aug 26, 2007
    30,126
    17,793
    YO11 2BD
    Could have been anywhere at any time.
  11. davejen
    davejen Funster
    Aug 21, 2008
    1,263
    718
    Kirkpatrick Fleming Dumfries
    Did you try anything else 240v-wise? was the leccy even switched on?
    Cheers, Dave(y)
  12. Manxcat
    Manxcat Funster
    Jun 22, 2011
    112
    141
    Isle of Man
    Well according to my theory if you plug the 3 pin kettle in and boil the water you have leccy.
Similar Threads
  1. sally47
    5
    262
  2. Josephine55
    12
    476
  3. ukbill
    7
    288
  4. Sidney
    3
    363
  5. Gollom
    13
    563
