Fridge broken locking plate
Discussion in 'Motorhome Chat' started by beachcaster, Sep 8, 2013.
  1. beachcaster
    beachcaster Read Only Funster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    The Dometic fridge on my autotrail has a puny thin sliding/locking plastic plate that has broken. I a bit of bad design as its too thin and fragile for the job.
    Has anyone got a better solution to this plate..or can you point me to where I can get a couple more as even a new one is going to break again sooner or later.
    Bad designers should be shot !
    barry:Smile:
  2. knokinonabit
    knokinonabit Funster
    Dec 28, 2011
    2,483
    2,453
    Stokesley, North Yorks
    Try going online as they have a customer support and spares department.
    www.dometic.com should get you started.
    You could also give them a piece of your mind about the product whilst you are on to them. :thumb:
  3. ourcampersbeentrashed
    ourcampersbeentrashed Funster
    Apr 19, 2008
    7,652
    4,284
    East London
    ours broke too whilst we were at the malvern show, luckily there was a stall with replacement part but at just under £15 we thought it very expensive for a few small bits of plastic
    if you cant get what you want there may be a stall at shepton or lincoln so post again if you are still stuck
  4. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,320
    17,030
    Liverpool.
  5. beachcaster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    Thanks for the info
    Just seen the price for a bit of plastic.....!!! Amazing
    So out to the workshop ( Im lucky to have some good equipment ) reglued it then re enforced it across the break with A thin strip of corian..re drilled the hole through the corian and profiled the new material to match the original shape then
    added two more thin strips of aluminium at either end
    Its now 10 times stronger than it was.......and all the reinforcing is underneath
    so cant be seen.
    This original part is just not up to the job.
    thanks for the replies
    barry
    • Like it Like it x 2
  6. hilldweller
    Dec 5, 2008
    27,723
    26,814
    Macclesfield
    Which is good until this new strength finds the next part that is sub standard and bit by bit you build a new fridge.
    Good Game.
    • Like it Like it x 4
  7. rrusty
    rrusty Funster
    Dec 4, 2009
    91
    57
    Scotland
    I replaced mine with a thin piece of aluminium
    • Like it Like it x 1
  8. grumps147
    grumps147 Funster
    Jun 6, 2010
    1,241
    894
    St.Helens
    And here I am thinking is only me who is cack handed. Ours has cracked right across where the hole is where the screw goes. So far just re-screwing it when it jams has worked. Where on earth do they get £25 :Eeek: from!
  9. BwB
    BwB Funster Life Member
    Apr 3, 2011
    612
    567
    Suffolk UK
    I don't know if my fridge catch is broken or not because it's missing completely. I didn't notice at the time of buying the van :Sad:
    Normally just put the water container in front of the door but reading through this I've just priced up and new catch assembly - one piece of bent metal and one plastic lever. Total price just under £40. BARGAIN!! I'll keep using the container:Laughing:
  10. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,176
    14,098
    Bolsover, Derbyshire
    Ours is broken, I removed the plastic slide bit and can then see the metal locking piece, which we can then move with a screw driver or finger nail if brave!! I guess they are all a bit different but you might not need the water container
  11. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,176
    14,098
    I totally agree, awful design, ours has broken, but we managed to get the slide off (unscrewed when open) now can move locking piece by hand or screwdriver. Not sure I am happy to pay £40 and have it break again, we were lucky to get it open first time. No access to steak or cold beer too big a risk David
  12. beachcaster
    Dec 18, 2010
    3,048
    3,171
    east sussex
    I agree how can they justify £20 for what must be a design that is not fit for purpose. I am going to have words with them tomorrow.
    I don't mind replacing something I broke because I was a bit brutal with it
    but there is no doubt that this is bad design.
    The screw is too big and exerts too much stress on the thin plastic that just breaks as you tighten the screw... it has no strength. Two small screws not pressuring the weakest point........thicker plastic
    or a metal plate rather than a plastic one would be better solutions.
    I will let you know what they say.
    barry:)
  13. tony_g
    tony_g Funster
    Aug 29, 2010
    390
    195
    Nuneaton,some of the time
    Ours has failed twice. Original glue repair lasted a few weeks but ultimately doomed. Short term I have taken to sticking a golf tee in the left hand alternative hinge mount into the corresponding hole in the door but the reinforcing fix described above seems pretty good.:Smile: :Smile::Smile:
  14. dna
    dna Funster
    Jan 17, 2010
    186
    200
    Cheshire
    Us too!
    Our catch broke as well. Having seen the price of replacements, we adopted the flick the metal catch by hand option.
    At this rate it would be easier to ask people to post if they haven't had this part fail. :Smile:
  15. grumps147
    grumps147 Funster
    Jun 6, 2010
    1,241
    894
    St.Helens
    The best fixes are often the simplest, excellent suggestion, thanks.
Similar Threads
  1. crabman
    15
    1,094
  2. Jim
    3
    296
  3. bertiebasset
    15
    561
  4. Josephine55
    12
    492
  5. EX51SSS
    22
    1,018
