Fridge and cooker vents (1 Viewer)
May 29, 2013
2,589
19,156
Tyneside
Chausson best of Flash 10
Several years now
Been looking at the vents for our Thetford fridge and grill. I'm surprised to see that there is no fine mesh grid behind the vent covers.
Surely wasps, bees or flies could easily get in there ? Are all vent covers like this ?
I know that there has to be a good air flow, but I'd have thought a mesh small enough to keep out flying pests would still allow enough air to get thro ?
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
no thats right if you had a fine mesh it would be harder for the sleeping gas lads to get trhe gas into the van .
i think its been designed like that so they can sell you gas detectors .
far safer to have a compressor fridge and no vents on the outside .
ought to be a law against vents .
scotjimland
2,231
9,713
A Woosh bang
If your fridge is fitted correctly,( as per Dometic /Electrolux instructions ,) the rear of your fridge should be sealed from the habitation area.. so a fine mesh grill not required..
If not, I suggest you have it done.. it not only stops draughts, but also, when using LPG, prevents CO gas (which we all know is deadly) from getting into the habitation area.
Sandancers
May 29, 2013
2,589
19,156
Tyneside
Several years now
Yeah, I understand the above and assume as the MH is brand new it should be sealed. But if a wasp or bee decided to build a nest behind the fridge that would not be a good thing for sure.
scotjimland
2,231
9,713
A Woosh bang
Indeed it wouldn't.. but frankly I doubt a bee or wasp would tollerate the heat behind the fridge.. certainly never heard of it .. but saying it can't happen is tempting fate ..
seen the odd spider in there.. :Eeek:
Puddleduck
12,377
43,924
Scottish Borders
Without at present
On and off for many years.
We have the start of a wasps nest at the back of our grill. The van is going back to the dealer's to get it sorted out.
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Just been out and looked at ours and there is no fine mesh on them. I did not look if we had any visitors in there but they will be in for a suprise on Friday when they end up in Bridlington
Sandancers
May 29, 2013
2,589
19,156
Tyneside
Several years now
Further information regarding the above.
I rang Thetford and there are two sizes of external vent.
Small @6" deep (width does not matter) and large @12" deep.
The small has a mesh fitted and the large does not !! They say that a mesh cannot be fitted to the large as it would reduce the airflow too much.
Which sounds a bit weird as there are covers which should be fitted when the temp is below 10c. Presumably the fridge can be run on gas with these covers in place and they must restrict the air flow a lot.
Won't be fitting a home built mesh cover, just in case something goes wrong and the insurance co. would not pay out.
