Fresh water tank (1 Viewer)
Bart
3,188
1,397
Northern Ireland
Boxer L4H2 van build
Since 2016
Still finding my feet around our newly acquired Bessacarr E560 when today i was filling out the fresh water tank and was thinking this was taking ages to fill , when i then seen water run out from below the MH.
Now when filling a vehicle with petrol or diesel you fill the tank up untill it comes up the neck of the filler, well u thought it would be the same for the freshwater tank , but nope on mine at the two highest points on the fresh water tank there are over flow pipes coming out of there so when you fill up the tank the only way to see if its full is to lissen for the overflowing water.
Is this correct / normal or is something wrong or missing with my freshwater tank.
Jul 29, 2013
9,067
18,408
Salisbury
Hymer B678DL A class
since 2011
I used to do that on our Exsis but found we were getting water in the tank enclosure on speaking to engineer at Premier they said to keep checking the gauge and stop as soon as it reads full not wait for overflow.
It's worked so far and no water in enclosure.
I believe it's because they are winterised and the heater heats around the tanks.
If yours is not winterised it's probably not a problem.(y)(y)(y)
Derbyshire wanderer
1,285
2,383
Derbyshire
C class
15 years
I have always filled my Bolero (same van different name) the same way till it flows over. It cannot do any harm and I know it is really full and not nearly full. As the tanks are underslung, there is no risk of wetting the internal floors ect.
Bart
Bart
3,188
1,397
Northern Ireland
Since 2016
@Derbyshire wanderer & @Speve Thanks for letting me know that was normal as i thought for a moment a pipe was missing or something :)
p.s i had the inspection panel of about the tank to have a look , and even right below the inspection panel there is another overflow point which is BELOW floor level , so theres no chance or overflowing into the MH :eek:
May 7, 2011
4,807
46,376
Cornwall Gorran Haven
T Line 785
motorhoming since 1979
I've got a Bessacarr 484,I always fill it until it over flows, as the water tank is mounted under the floor & even if it came out of the tank lid ,it still wouldn't get in to the van
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
I rarely put more than 40 litres in the tank, the gauge never shows more than 1/4 full.
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Just another thought on the E560, the waste tank is impossible to overflow. If you get under the rear of the van and look closely at the side of the tank, near the top, there are a series of holes drilled so the water flows out rather than back up the waste pipes. Probably the same on many other vans.
May 7, 2011
4,807
46,376
T Line 785
I thought he was talking about the fresh water tank over flowing when filled.
43,295
49,268
If you have a fast enough flow through the hose INTO the tank then water will flow in faster than the smaller bore overflow will let it out so eventually it will run out the filler hole....but that's wasting water.
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
He was but most people don't know about the overflow holes on the waste water tank.
Jun 22, 2014
557
748
Great Totham
PVC
Since 2015
i fill our bolero until it overflows. Same as you i listen. Don't seem a great way of doing it but i've not come up with a better way to fill it right up yet.
Bart
Bart
3,188
1,397
Northern Ireland
Since 2016
Wow really surprised they make so many motorhomes fresh water tanks like this , so much for save the planet and save water etc :)
About time MH designers started making the freshwater tanks like petrol tanks , as sealed tank with a breather pipe leading into the filler neck (y)
Bart
Bart
3,188
1,397
Northern Ireland
Since 2016
Strange enough i noticed them over flow holes today when i was in below my waste tank. i thought someone had did them as an aftermarket modification :)
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
I use my trusty watering can and usually leave home with 30 ltrs. in the tank. No waste and much faster than using a hose.
Jun 22, 2014
557
748
Great Totham
PVC
Since 2015
i have a watering can too, which is handy but not as quick as a hose. Also carry a aquaroll and a whale pump.
FrankCoffi
61
39
Andover,Hants
Lunar Premier H592
since 2007
I find that I carry the least amount of water I need to get me to where I'm going,so we can have a drink on the way if needed and a little extra for any other need.
The more water you carry the more fuel you use,due to the extra weight carried ??? Fill up when you arrive at the site,unless you are wild camping I don't see the point of carrying so much water.All this is irrelevant if you are talking about filling when on site (lol).
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Our Autosleeper had an auto shut off so you couldn't overfill. We always travelled with it full (110 litres) as we never went on sites.
When I filled our current van up, I didn't even think about auto shut off or overflow, then realised water was coming out of the overflow and the tank was full.
It took a bit longer than our other van, the new one holds 270 litres. We travel with this one full too, and although we have a level indicator in the van, we can see the side if the tank and being translucent, are able to check accurately how much is in it.
We also have a city water feed that can be connected permanently, this has an auto shut off so the tank won't overflow when it's connected.
Jaws
23,830
72,328
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Same as the Autotraill we have..
Always keep it as full as pos cos we are fairly hard core motorhomers and sometimes do not see a tap for several days when touring !
The Lobster
321
325
Borders of Scotland
Bürstner A576
Still getting started
Someone did an interesting calculation around this on another thread showing how this was a myth - and that the extra weight of a full water tank made a minute difference to the mpg.
Allanm
5,431
9,192
Since 1987
There was a Whale connector that plugged into a connector on the side of the van. To fill up, you needed to turn on the control panel and a solenoid opened to let the water into the tank. When the tank was full, the solenoid operated again and shut the supply off.
One of the benefits of this system is that you could leave the supply connected and it would automatically top the tank up when needed.
Similar to the City Water Line on American RV's. We have that on ours.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
carry more beer and wine than that pappa .
havnt bought any in uk for years .
oh and 400litres of diesel. ha ha .
not including the red for the genny.
