I'm replacing the 'Outlet cap ' on the top of the fresh water tank (Hymer B654) and also the tubing between the cap and the submersible pump (this follows a not so successful replacement pump and tubing fitting last year where the tube now keeps separating from the old outlet cap - hence why I'm replacing the cap!).
I'm finding it difficult finding a tube with the right internal and external diameters (and it's got to be 'foodsafe?' as it's constantly underwater in the tank). Anyone done a similar replacement please?
I'm also having a problem figuring out how the screw tops supplied with the pump and Outlet cap are supposed to work? They don't appear to be tapered inside so how can they tighten on a tube??
Finally, the original tube was rigid (and used push-on Reich fittings) and I think a rigid pipe would be better as the pump wouldn't then slosh about at the bottom of the tank - just a thought!
Any help would be appreciated,
Thanks,
Confused!
Thanks,
Confused!
