Fresh Water Tank Locking Cap (1 Viewer)
dellwood33
878
Newcastle
italian crap
too long
Is it just me or do others have problems in unlocking the cap on their freshwater tank ?
One time I can unlock & remove it without any problems and then the next time I have to fiddle about for anything up to 10 minutes to get the cap unlocked & removed.
Are there any remedies or do I just need a new cap :Smile:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Thats why Beer Bottles are made so easy to open:thumb::ROFLMAO:
Joking aside it seems a very common problem, and a new cap cures it, but it soon returns:Doh:
You could try lubricating the key by rubbing a lead pencil over it or using dry graphite grease dont use WD40
dellwood33
dellwood33
878
Newcastle
italian crap
too long
I have tried the graphite trick, but it still is a lottery as to whether it wants to unlock or not. Think I will leave it unlocked & see about a new cap (Size XL and with a peak before anyone comments) at Stratford :Smile:
3,977
6,197
Rochester
Auto-Trail Mohawk
16 fun filled years
Yep same as above Silicon Grease is what I used, had no problems since.
Maplins do a small aerosol can of it Link Removed
bazfergy
558
4
dumfries scotland
a class
5 years
water cap
Hi dellwood I turn the key before turning the lock and that usually works:Doh:however my wife always struggles with it:Eeek: and a bit of grease doesn't hurt:thumb:
shifter
67
wee island across pond NI
coachbuild
3 years
HI DELLWOOD
this does work and it costs nothing
take cap off and submerge it in boilling water for about 40 seconds.
you can even hear it click into place when you lock it.
CHEERS IAN
1,288
275
Billingham
since 2003
HI DELLWOOD
CHEERS IAN
doesn't that hurt your fingers
American Dream
156
Lincoln
Doesn't greasing the cap taint the water or do you take along another source for drinking?
I've always wondered what's going on in the world when one has to resort to locking such a device.
Mine has the older type fillers that i have just replaced with original fittings.All plastic.No metal comes into contact with the water and a lever (plastic) that can be locked if really required.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
hi shifter, there,s about a hundred vans been put in boiling water now. you didn,t make it clear it was the cap. please explain things more properly .
shifter
67
coachbuild
3 years
HI DELLWOOD
take cap off and submerge it in boiling water for about 40 seconds.
CHEERS IAN
i think my post is quite clear :Eeek: :thanks2:
CHEERS IAN
peter marshall
2,466
1,704
Cleveleys,Lancashire
Low Line
9 Years
hi we had a OMNISTOR cap which was trouble, it finally would not come off at all, I fitted a new FIAMMA cap and base fitting (very easy just 3 screws a clip on the water pipe a bit off white sealer round the outside for water ingress protection) the fiamma as a proper interlocking cap and is so much easier to use ps I got mine from Pickering show last year about 15 pounds i think. Peter:thumb:
dellwood33
dellwood33
878
Newcastle
italian crap
too long
Shifter - Just tried your boiling water trick & it worked a treat.
You are right - you can here the key clicking, something it never did before.
Cap now locks & unlocks when I want it to & not when it decides it is convenient.
Thanks for the Tip :Smile:
American Dream
156
Lincoln
:ROFLMAO::ROFLMAO::ROFLMAO:Visions of all these vans.Where do you get all this water?
Don't all these lubricants taint the water or don't you drink it?
43,293
49,250
HI DELLWOOD
CHEERS IAN
tried that.....now me caps too small for me 'ead.
are you going to compensate me for giving poor advice :ROFLMAO::ROFLMAO::ROFLMAO::winky:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
hey pappa its summer now u dont need the cap ,just use one of those straw thingy,s. i guess its not a safety cap, (squeeze in the sides then turn. ):ROFLMAO::ROFLMAO:
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
good job it was afresh water cap . not a grey water, or even a black water cap , you,d be in the s**t then thats for sure . the kettle or pan wouldnt be too nice afterwards either .i,ll look for a new one for you in holland pappa dont want you feeling the cold.
484
I had a similar problem on a Euro Mobil van I had and I discovered the the key had very small notch in the top and if it was turned about 2mill too far the notch would catch and prevent the key being removed, once I got the hang of the key being in the right position I had no further trouble and was able to lock it easily, as my van was new at the time I was supplied a new cap after complaining , but never needed to use the new cap as I got the hang of the old one as explained and was too embarresed to own up that there was nothing wrong with the original.:Blush::Blush:
Baggins
82
Torbay
Hi Top
fresh water cap
A couple of months ago my boy saw me struggling with the water cap and - not knowing the boiling water wheeze - took it apart quite easily and found the lock-pin locating spring had miss-aligned.
Job Done.
