Fresh water system problem (1 Viewer)
Gellyneck
9,220
18,190
Scotland
More than toes wet now!
Just back from our last trip away in our 2013 Auto-trail Savannah and after nigh on three weeks of the water system working fine (hot, cold and toilet) all of them start spluttering so there seems to be air getting in somewhere.:(
Checked all the pipework, joints, pump, filter, etc and all seem bone dry which leads me to believe (and after reading various threads on here) there could be an issue with the pump with it letting water drain back down into the fresh tank.:unsure:
Now for the questions,
  • any other thoughts on what it could be?
Assuming it may be the pump I've searched online with no success in finding an exact replacement - model number is Shurflo 4029-181-A32. This pump seems to be a quad diaphragm model and is rated at - flow = 7.5l/m, shut off pressure = 20psi, amps = 3.5 max, 12v. I've found a number of triple diaphragm models, eg Shurflo Trail King 7 2095-204-112 & 412 rated at 20psi, 7.0l/m .
  • Anybody know if the 4029 model is available and I'm just useless at searching?
  • Is the 2095 model a suitable alternative?
  • Any other options I should be thinking about?
Appreciate your help gang.(y)
Badknee
7,407
412,582
notloB
Vantage Neo
Living the dream.
IT will be cheaper putting a one way valve inline between tank and pump.
Gellyneck
Gellyneck
9,220
18,190
Scotland
Any pictures available?
This is what's currently fitted -
Your link is to the "manual" for the fitted pump (great (y)(y)(y)). If I'm reading it correctly you say you've sourced and fitted a replacement one. Any link to where you managed to get it from?
Many thanks
TheBig1
17,630
43,262
unlikely to be the pump. it is more likely grit in the non return valve near the tank. only a couple of quid but often a right PITA to get at an replace. its only a plastic ball and a spring held inside a shaped piece of tube so can often be washed out under a tap at mains pressure, but once they start failing they will soon need replacing
Gellyneck
Gellyneck
9,220
18,190
Scotland
This is another option I had thought about but not sure I'll have enough space to fit as pipework disappears straight through the floor into the top of the tank.
Gellyneck
Gellyneck
9,220
18,190
Scotland
On checking the manual linked to by PPBear it says the pump includes a check valve. Would this be the same as a built-in non-return valve and therefore maybe not a valve fitted before the filter?:unsure:
Pipework disappears straight through the floor into the top of the tank but, as you say, a bu**** to see and confirm this!:mad:
TheBig1
17,630
43,262
if it was me, i would cut the pipe as close to the tank as possible and fit an extra non return valve if possible. the problem is the last foot or so of pipework will drain back to the tank when the flow stops
Gellyneck
Gellyneck
9,220
18,190
Scotland
Will crawl under, have a look see and let you guys know how we get on.(y)
Thanks for your efforts.
Gellyneck
Gellyneck
9,220
18,190
Scotland
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
Interesting thread. Alan has almost the same problem on his autotrail but it's a possiflow pump.
Maybe this thread will help him too :)
Gellyneck
Gellyneck
9,220
18,190
Scotland
Just been reminded by another Funster that I hadn't given the final outcome of the problem (thanks John) so better late than never!:rolleyes:
Not much of a solution right enough as it just seemed to resolve itself a couple of weeks later on our next trip.(y)
Kinda guessing it was just a bit of grit sticking the valve open that cleared itself (as suggested by @TheBig1 above).
Oct 15, 2011
4,161
11,262
Not Glasgow
Carthago chic eline
Since 2011
Lucky one, would have been funny seeing you try to crawl under the floor. :rofl::rofl::rofl:
43,323
49,435
Many thanks
That's for the US market, not the EU.
It's rated at 2 AMERICAN gallons per minute... A US gallon is only 3.75ltrs
Try some of the RV dealers.
Oppps, just realised the thread is almost 2 years old.
