Fresh water problems.
Discussion in 'Motorhome Chat' started by Kent monkey, Apr 20, 2015.
  1. Kent monkey
    Kent monkey Funster
    Mar 25, 2015
    23
    3
    Halling village rochester kent
    help, I have a new problem every time we go away in our elddis autoquest 140.now the water to the sink is only intermittent. but seems ok at all the other points ie.bason shower,and wc does anyone have any idea.s as to why it would not work to the sink but be ok everywhere else.the dealer said they had never heard of this and was unable to surgest what was wrong or how we can fix it..
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,102
    17,771
    YO11 2BD
    It may be a faulty micro switch at the tap if it has micro switches.
    If unsure have a look under the tap....any tap....and see if it has a pair of thin wires hanging down.
    if it has its got switches, if not its pressurised and could be a different fault.
    My money is on switches.
  3. Timotei
    Timotei Funster
    Jul 23, 2012
    51
    72
    Kingswinford
    Had an intermittent fault with our kitchen tap, took it apart, found one of the thin wires to the micro switch was broken under the cover. Soldered it, insulated it, tested it - job done
  4. Kent monkey
    Kent monkey Funster
    Mar 25, 2015
    23
    3
    Where would the switches be papa johns as I don't have a clue
  5. Kent monkey
    Kent monkey Funster
    Mar 25, 2015
    23
    3
    How do you take the taps apart did try but didn't,t want to force it
  6. pappajohn
    Aug 26, 2007
    30,102
    17,771
    YO11 2BD
    The switch is usually INSIDE the tap and the tap usually needs to be removed to access it.
    How its removed will vary on tap make.
    Never having had a microswitched tap i dont know for certain but i believe on some you remove the top cover and unscrew the centre screw to remove the tap handle then you can lift out the switch.
    Other foreign taps have a removable Insert containing the switch and you replace the whole insert.
    • Like it Like it x 1
  7. Kent monkey
    Kent monkey Funster
    Mar 25, 2015
    23
    3
    Thanks for the info I am going to speak to the dealer about this and see what he.s got to say.
  8. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,688
    23,082
    Narrfoook
    Are the taps the mixer type ?
  9. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,014
    13,868
    Bolsover, Derbyshire
    I am totally untechnical, but do like to diagnose where I can, I suspect micro switches like above
    to test this turn on the tap that doesn't work, presuming it still doesn't work leave it on and turn on your bathroom tap, if both run then run perfectly the micro switch is almost certainly to blame
    if it doesn't but the bathroom one does then it maybe an air lock or other issue
    I cant help at all with how to fix it, I would be getting it done at my service centre, or more likely using the bathroom tap to get water :)
    rereading my words it might still depend on whether your system is pressurised (y)
    probably no use at all, but I like to try and help:)
