French Connections (of The Hose Variety). (1 Viewer)
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
Since 2012
Oh no! Not MORE hose connectors and adaptors???
I thought I'd cracked it. I've got a box of every conceivable hose adaptor required for the various UK (and particularly French) taps; or so I thought!
It appears that the French have been making changes to some of their fresh water service points on Aires. These service points - named Urbafox - have a different connector to ones we are normally used to. I also came across an article regarding this in MMM magazine which seems to confirm their growing use.
These Urbafox service units require a sort of hozelock male-to-male straight connector which fits the unit and then another adaptor onto your hose. They are similar in design to hozelock, but not quite the same size?
Has anyone come across these new service points?
Feb 28, 2013
187
294
Carterton, Oxfordshire
Since 2012
Two weeks ago at Villandry Aire. Had to keep pressing in the hozelock male to male, got soaked and lost a great deal during the timed session. A Dutchman took pity and lent me his adapter, only fractionaly longer ( 2mm?), wouldnt know where to obtain one. Perhaps the brass hozelock adapter may fit better.
Jul 31, 2014
1,930
3,241
West Yorkshire
EuraMobil Activa 820HS
Didn't the MMM article mention the name of the company (like hoselock) that made them along with where to buy them?
I'd look in the MMM but I've just given it away, so if you've still hit a copy, can you let me know? If not I will ask for the mag back and will check and post on here.
Dec 12, 2010
5,410
21,560
Cumbria
since 2011
Not yet, but you can get a male to male adapter in the Range for under two quid, maybe not much use to you if you're away but a male to male adapter may help @old-mo with his request in his recent post :LOL:
edit, just read Pete's post about it being 2 mm longer, may be the clincher for Mo ?
RicknSue
17
15
Galmpton, UK
10 years
I just looked at the MMM article. This is the information for buying the parts online from the French DIY chain LeRoy Merlin.
Gardena 616-26 hose adaptor female part sold by Leroy Merlin as 66741836 €4.95
Hose joint male to male 931-26 Leroy Merlin part number 6674205 €2.95
Leroymerlin.fr
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
At Nante Municipal camp site I used Hozelock m/m successfully and also bought a Robinet (tap) that fits as well-handy if you just want to fill a container.(y)
wingman
wingman
1,217
3,333
Romford, Essex
Since 2012
After writing the OP, I did a bit of hunting. Looked on Amazon as they do Gardena fittings. On looking at the item description of both adaptors it appears the part numbers were the same as the ones on the French Leroymerlin website.
As I'm going to do a lot of Aires this summer and even though I have loads of hozelock stuff, I bought the straight adaptor and the corresponding connector so that I don't get caught out.
This is in the full knowledge that some funster or other will come up with a work-around (n)
Jul 31, 2014
1,930
3,241
West Yorkshire
Look at www.worldofgardena.co.uk
Prices are similar to Amazon and they offer different postage options depending on his quickly you need them. Codes look to be the same.
RicknSue
17
15
Galmpton, UK
10 years
Mike and Carolyn We were at the Nantes Aire ( on the University Campus) about 10 days ago, we filled up successfully and I didn't notice that they had adopted the new system. I cant actually remember which adaptor we used. WillH filling up a 110 litre tank might take awhile from a watering can and we have a Whale pump sysyem
Feb 16, 2013
19,734
52,019
uttoxeter
ambulance conversion
50 years
If it's a male out can't you just shove your hose over it
RicknSue
17
15
Galmpton, UK
10 years
I haven't come across them personally but according to the article in MMM its a female connection and its called an Urbaflux Totem CC and its being fitted on quite a few aires. I would imagine quite a few French motorhomers will have problems too.
colinw
523
306
Bolton , Lancs.
low profile
Under a year
Mother in law just bought me the 2 connectors , just need to pick up a watering can now and I'll have all angles covered .
Thanks for another helpful post guys !
2 weeks until our French trip begins .
Jul 3, 2008
1,098
943
Lincolnshire
Autotrail Apache 700
since 1998
Nip in to a bricolage ( DIY) and buy one there
