frankia A class (2 Viewers)
Plup
4
Naas Ireland
A class tag axle
since 2005
Hi all would be interested in speaking with some 1 with frankia with truma heating as we purdhased ours 3 mts ago and have few queries we would like to resolve ,heating does not seem to work on electrics only also manual wind up sky dish does not pick up signal,any adv would be appreciated
Regards Denis
Heyupluv
3,862
1,593
France,
touring many years..42+
Regards Denis
I think the heating you mention are widespread being fitted on most motorhomes
as I understand there three models ...Truma 4...Truma 6 ...Truma 6 EH and I think it is only the latter the 6EH that is gas and Electric... what model do you have :whatthe: little more info may help the funsters help you....does your controler have any lights on,.. is there a fuse have you checked
Mel:thumb:
Just been looking Truma site and they may now have electric in all models ?
Heyupluv
3,862
1,593
France,
Hi all would be interested in speaking with some 1 with frankia with truma heating as we purdhased ours 3 mts ago......also manual wind up sky dish does not pick up signal,any adv would be appreciated
Regards Denis
Hi Denis is it possible a little more info.............................is everything connected...is the dish up....have you tried to find a signal...have you pointed the dish in correct direction....did you find the correct satilite....is the television switched on.....Etc:...were do you think the problem may lie, what do you get when you try
Mel
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Hi Dennis
cant help with the heating,
But as for the Sat dish :Doh:
Any form of manual alignment is a true Black art, you could play around for days and get knowhere with it, however once and I mean once shown you will be able to locate astra 2 with your eyes shut.
Read as much for as long as you like, till your shown it will seem like a lost cause
If it helps wev'e all been there:RollEyes:
Geo
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Hi Denis, have you now connected you dish etc in the correct order.
dish-satfinder-box-tv
You will find the main sats are in 2 different elevations
hotbird will be set approc 10 deg higher than Astra.
So switch on your TV/Box etc and go to the setup menu, setup antenna, make sure you can change between the various stats and see the signal strengths on the screen. Turn the dish until you receive max signal. then adjust elevation for max signal, a starting point of 22 degs is good for Astra and 30 deg for Hotbird.
when your sat finder is at maximum, check through the sat signal strength for individual sats
note which one is giving the best reading. (You could mark the position with a pencil on the shaft and clamp to give you a referance point. If it is hotbird then change the elvation to a lower number , deduct 10degs for a start, then turn the dish very slowly anti clockwise until you reach the next peak. Check and mark only the clamp this time (in line with the pole mark). continue this until you find Astra, it is around 20 deg anticlockwise from hotbird. As a starting point I use 30deg el for hotbird and 20 for Astra. Depends where you are but the relationship remains constant. find one and it gives you an idea where the other is.
As a rough guide point the dish at the sun at 10am and you will not be far from Astra. (Alan laneside will tell you if that is BST or GMT, hee hee)
