francour (1 Viewer)
francour
94
13
Pontefract
a class
since 1990
Hi all hym 544 suspension very hard on the rear. springs fine and leaf springs ok would new shocks inprove it what are the signs of worn shocks Thanks :Smile:
slobadoberbob
6,151
1,960
Kent, garden of England
Winnebago 23' something
25 years & counting
welcome to the forum
welcome to the forum.
I expect someone with a Hymer will be a long to answer your question soon.. but have you considered having rear air suspension fitted... fairly common these days as an after fit... I know it did marvels on my American RV.. stopped bounce and sway.
Bob, Sue and Ezzie the St Bernard.
spannermanwigan
392
207
wigan, lancs
coachbuilt
since 1973
1) Excessive bounce.(travel in suspension).
2) Oil on outside of shocker body.
How high are your tyre pressures? What should they be?
How much gap do you have between your axle and its bump stops?
Feb 1, 2011
209
146
Redcar
Hymer C. Class
26 yrs
coldstreamer
Hi,
I have had my present 544 for 8 yrs and a cracking bit of kit, but after about 3 yrs I found the ride harder and a bit unstable. Decided to fit Air Rides and a huge difference. I have found I need to adjust the pressure to allow for the load. Just normal wk-end jaunts no probs, but long trips with heavy loading demand a bit extra pressure. I think just use your common sense and trial and error. To find the right pressure I look for a small upwards curve on the springs, which is how it should be empty.
I'm sure without the Air Rides I would struggle.
I bought them from 'Marcell. Very good company with good instructions. Half hour to fit the first one, ten minutes for second Best Regards Mac.
DESCO
2,646
266
London
low profile
18 years +12 years tugging
Not had a Hymer but had Air-ride springs fitted to a van, the difference it made was unbelievable went from a van that seemed unstable, and I did not like descending steep hills that twisted around next to steep drops, to a van I had complete faith in.
In my opinion money well spent.
