dshague
- Aug 22, 2007
- 996
- 302
- VAN CONVERSION
- 20 years
RE: TRUMA BOILERS-PLEASE READ
I am finding that a few Motorhomes I have been working on have not had their Truma Boiler modifications carried out. If you have the following heaters in your MH Trumatic C 6002/C 6002 EL/C 6002 EH/C 4002/ C 4002 EL then please read the attached file and check your serial numbers to see if they need the safety modification. I believe it is motorhomes pre 2008 but still might be worth a check. Those with a "Truma Checked" label have already been done at the factory and those with a white dot on the Fan housing may well have also been exchanged. If you find that yours does need fixing then contact Truma direct first
https://www.dropbox.com/s/pp2r074uruulqu0/Truma.pdf?dl=
