Ford easy fill fuel filler
Discussion in 'Motorhome Chat' started by etap, Mar 7, 2015.
  1. etap
    etap
    Nov 19, 2014
    256
    233
    Somerset
    Just picked up new motorhome with the new ford Diesel engine and it has this new easy fill fuel filler cap, does anyone have any experience of these? Good or bad or other ? As I don't understand why the filler hole has to have a plastic separate nozzle to fill up with diesel, which makes the hole bigger, can understand it the other way round??
    Etap
  2. martin1485
    martin1485 Funster
    Jan 26, 2010
    443
    666
    Conwy, North Wales
    You just push the pump nozzle into the centre of the cap. The plastic nozzle is only meant to protect the filler tube into the tank if you need to use a portable fuel container. The handbook for my Ford car states:
    "Do not insert the nozzle of portable fuel containers or aftermarket funnels into the capless fuel system. This could damage the fuel system and its' seal and may cause fuel to run into the ground instead of filling the tank."
    "When filling your vehicle's fuel tank from a portable fuel container, use the funnel included with your vehicle"
    "When you insert the correct size fuel nozzle a spring loaded inhibitor will open. This helps to avoid filling up with the incorrect fuel"
    Your Ford owners manual should give further instruction on the correct way to fill and avoid damaging the filler neck.
    • Like Like x 1
  3. TG1903
    TG1903 Funster
    Oct 25, 2014
    26
    55
    N.E . Scotland
    I have the Transit Custom panel van and the plastic filler bit is only needed if you need to fill from a diesel container , otherwise the diesel pump just fits as normal.The one thing I would say is after filling allow at least 10 seconds before you remove nozzle otherwise diesel drips out down the side of the van .I am waiting delivery of a Chausson on Ford transit chassis .
    • Like Like x 1
  4. Eddystone
    Eddystone Funster
    Feb 26, 2012
    234
    141
    • Don't know if I have a plastic funnel anywhere in the car but putting fuel in from a pump is fairly straight forward. Push the nozzle against the plate covering the filler hole and insert the nozzle. If it isn't in far enough the delivery will shut off automatically. Then as TG1903 suggests, wait about 10secs before removing the nozzle.
    • Like Like x 1
  5. Weinsbergaman
    Weinsbergaman
    Feb 8, 2015
    221
    197
    Wirral, North West England
    They are great, no more struggling with a filler caps or keys. Open up, fill up, close, pay and go. No key, no messin, nice and quick. Well done Ford.
    • Like Like x 1
  6. etap
    etap
    Nov 19, 2014
    256
    233
    Somerset
    I was under the impression from the dealer that with Ford Diesel engine one can only use a diesel pump at a filling station if you insert the plastic tube first, as the diesel pump nozzle is too big to go in the filler tube, is this correct or not?
    Thanks for any replies.
    Etap
  7. Shovelheadrob
    Shovelheadrob Read Only Funster
    Jul 13, 2014
    60
    111
    It's as simple as this
    as said the plastic tube is so that you can use a can should the need arise. The only diesel nozzles that may be too large will be some HGV diesel pumps as they are faster fill. HTH
    • Like Like x 1
  8. TG1903
    TG1903 Funster
    Oct 25, 2014
    26
    55
    N.E . Scotland
    Is far as Iam concerned the dealer doesn't know what he's talking about ,the diesel nozzle does fit without plastic filler pipe .The Plastic bit is only for filling from a container(Jerry can style).
    P.S My custom panel van is the 2.2 Diesel , same as your motorhome
    • Like Like x 1
  9. etap
    etap
    Nov 19, 2014
    256
    233
    Somerset
    Thank you everyone for your help. I will inform the dealer!
    Etap
  10. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,940
    West Norfolk
    Trust someone to try and reinvent the wheel (or hole in this case!).
  11. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,544
    2,558
    Trowbridge
    It's great.. you can't misfuel... Only diesel models will open the thingy if you try and put petrol in it just runs out over the tire.
  12. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,275
    7,940
    West Norfolk
    They won't like it in Norfolk, farmers and gypsies won't be able to fill from red diesel tanks!:)
  13. Masman
    Masman Funster
    Sep 25, 2009
    304
    195
    south yorkshire
    I've got a 2010 ford focus.Went to fill up.put diesel in.came to remove nozzle.No chance:(.After a 30 min struggle.Ended up ripping the top off filler.went to Ford garage.turns out after a few years the plastic gets brittle.To replace it is a big job.according to Ford you have to drop fuel pipe from inside..on speaking to mechanic the plastic bit is shit.But you don't need it.no water can get in & underneath the plastic is a spring loaded metal cap(y).so if anyone has same problem don't worry you can still fill up and no worry of water getting into tank.
  14. etap
    etap
    Nov 19, 2014
    256
    233
    Somerset
    AsI started this issue I can now confirm having filled up our new MH this morning with Diesel, just as has been pointed out the plastic funnel is only for filling your tank from a container, otherwise fill up as normal.
    It is surprising tho. How many people have not heard of these new easy fill caps.
    Thanks everyone your all correct again.
    Etap
