foglight obscured
Discussion in 'Motorhome Chat' started by mike mcglynn, Aug 8, 2011.
  1. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,432
    6,053
    St. Helens MERSEYSIDE
    Hello all Can I ask for some advice Ive had a towbar fitted and it obstructs the foglight :cry:what wire type/size do I need to move it to a better position also is this a fail on mot :Eek!:thanks in advance
    mike
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,118
    17,786
    YO11 2BD
    fail !!! i'd say yes.
    wire...same size as already used but make sure the joint is waterproofed.
  3. upmarkethippy
    upmarkethippy Read Only Funster
    Feb 25, 2008
    364
    81
    Hull
    if you use vaseline on the joints, it will help keep moisture out....
  4. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Just grab some heat shrink and slide over soldered joints and you will be fine.
    Each Fog will draw 4.5a on a 55w bulb - so 10a cable will do nicely!
    Let me know how much you want and I'll throw some in a envelope for you!
    • Like it Like it x 1
  5. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    most rear fog lights are only 21w bulb though
  6. rainbow chasers
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Always go by the maximum probable load! :thumb:
  7. pappajohn
    Aug 26, 2007
    30,118
    17,786
    YO11 2BD
    i believe that is the maximum allowed under vehicle lighting regulations....just as 60watt is the legal max headlamp rating.
