flushing (1 Viewer)
lugnutt
1,190
466
wednesbury.westmidlands
autotrail apache
10 years
hi ....al this talk of flushing black holding tank with gray tank,i have a c class with two outlets one for eatch never flushed with gray tank is this just my rv or am i missing something? one tank eatch side:Eeek:
Jim
Ringleader
Jul 19, 2007
36,417
130,895
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Many RVs share the same exit pipe, so in theory if both valves are open, the tanks are connected, so by leaving the black open as you flush the grey, some grey will inter the black and flush it. That's the theory anyway. I never did physics but I do not think it would work on my tanks as they sit to high and I am sure that only a dribble of grey would manage to get to the black tank.
So (on my system at least) the grey is good for flushing the hoses but not the black tank, trouble is the grey often stinks more than the black so I always flush with fresh when I can. Our tank has a cleaning jet inside it so you can hook a hose to it and it whizzes around inside like one of those "Crazy Daisies" and I usually run this untill everything is running "clear"
des
128
south staffs
RV
5 years
i flush my black tank using a "swizzle stick" down the toilet every once in a while. i put a clear 45 degree adaptor between the outlet and the sewer pipe, and flush until the water runs clear. i keep a separate hose for this, to avoid any possibility of subsequent cross contamination with fresh water.
des
pudseykeith
382
105
Leeds West Riding of York
6 Years
Keeping things sweet
Hi Guys
When we clean the kitchen sink, bathroom sink and the shower we do this with a bleach / water solution. We never allow food particles to be flushed down the kit sink. All food is wiped off cutlery and crocks with kitchen roll and binned. Result - there is no smells coming from the gray tank. All drains have a 'U ' trap in the pipes. When draining the gray tank, there is no smell at all.
After draining the black tank, before disconnecting we open the loo and pore in a bucket of fresh water. Result, no unpleasent smells from either. :thumb:
Pudseykeith and Rosalie. :Smile:
ruffingitsmoothly
Jan 2, 2008
553
70
West of Southampton edge
A Class RV
Hi Jim you can partialy flush the black tank with the grey if you are dumping into a manhole or grating as follows: dump all of the black then with the black valve still open lift the dump hose upwards so the open end is above the level of the tanks then open up the grey valve this will cauase the tanks to equalise then carefully drop the hose into the manhole or grating.
I'm in agreement with you though in as much as I find the grey waste to be far smellier than the black, and I have a flush sprinkler in my black tank anyway.
Regards Pat
superk
495
57
Devon
Van Conversion now sold
8 years
Regards Pat
I think I saw that demonstrated in the film RV :ROFLMAO:
::bigsmile:
Keith
lugnutt
lugnutt
1,190
466
autotrail apache
10 years
thanks for all your input ....but mine has two outlets gray on drivers side and black onthe other side not linked is this just my rv or are all c class like mine?
