Flot Bleur Leccy Tokens (1 Viewer)
Feb 22, 2016
3,609
10,709
York
Bailey 620 Approach
Since 2015
Hi all
Daft question possibly but can anyone confirm whether you can pay more than 1 token at a time? We're at an aire at Moulins, Auvergne that accepts Flot Bleur tokens. 1 token gives 4 hours of electricity. We want to be here over 12 hours. We don't want to have to go out every four hours in the middle of the night. It is due to be -12 tonight so want the heating on all the time.
Think it ought to work like a car parking meter. You can pay in advance for the time you require.
Sorry if this seems daft.
DBK
18,022
48,088
Plympton, Devon
PVC, Murvi Morocco
I don't know but there's an obvious way to find out. :)
I suggest you put just two in and if it doesn't go off in 4 hours then put a third in. Possibly best to wait until four and a half hours have gone by, just in case it has a slow clock. :)
If it does go off after four hours you may need to dust off the alarm clock. :)
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Once you are ready to turn in, just switch the heating to gas only. Our Truma is gas only anyway and if it's very cold, we simply leave it ticking over all night at the lowest setting.
Ingwe
Feb 22, 2016
3,609
10,709
York
Bailey 620 Approach
Since 2015
Thanks. Before we posted, we put in 1 token. Then hooked up and thought about it. So 10 mins elapsed after we put the 1 token in. When we went back, just now to add further tokens, there was a bar across the token slot. So maybe you have to do it at the outset. We'll try adding more tokens at 9 and see if we can add more than one.
@JeanLuc- we will put our Truma on lowest gas heat but keep the leccy on as well. -12 due tonight! Brrrrr❄️
Ingwe
Feb 22, 2016
3,609
10,709
York
Bailey 620 Approach
Since 2015
Sorry for delay in replying; been without wifi for a couple days.
Well, exactly on 9pm, the power went off. The slot to the source we were using was still locked. So we plugged into source 2 and put 3 tokens in. Had 12 hours of power! So live and learn. However, it seems to be the case that you can only put in 3 tokens (12 hours) at a time.
