Flippin Radio
Discussion in 'Peugeot' started by AdgeRas, Jun 23, 2010.
  1. AdgeRas
    AdgeRas Read Only Funster
    Sep 17, 2009
    495
    9
    Bristol
    Hi folks.
    We are out touring at the mo, but the radio/cd in our peugeot cab MH (Feb 2006 Compass Avantgarde 200) decides that it wishes to turn itself ON after I have turned the ignition OFF and taken the keys out of the ignition.
    If I turn it off, it sometimes obeys and stays off, but sometimes it decides to turn itself back on....................Any thoughts please?????
    Adge
  2. shirlandy
    shirlandy Funster
    Apr 19, 2009
    190
    52
    Rotherham
    i dont know if this helps but my Renault Scenic does this,if im washing the car i can put the radio on without the ignition,but it goes off after 15 mins.
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,909
    17,578
    YO11 2BD
    if its the genuine radio then i'd say you had a problem.
    should be able to play it for around half an hour with ign in acc position then it turns off. (conserves battery power)
    but is fully off with key removed.
  4. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,069
    DERBYSHIRE
    In the past Blauplunk has had a problem with stereo turning on in my car it would do it sometimes
    Field Remedy: 1979
    Subject:Radio CD30/CD30MP3/CD50Phone
    Flat battery due to self switching on of the radio Models:Engines:Option:Astra-H 2004...2005,All 2005All,All
    Complaint:Flat battery due to self switching on of the radio.
    Cause:Malfunction of the "CD-In-Recognition" switch of the CD drive.
    Production:Modified radio devices have been implemented as of: Astra-H (Bochum, Ellesmere Port, Antwerp): W0L0AHL3552121099 04.02.2005 W0L0AHL4858073270 07.02.2005 W0L0AHL4855140513 22.02.2005 VectraC, Signum (Rüsselsheim): ...51 083 965 28.02.2005 Combo C (Azambuja): ...53 039 620 28.02.2005 Corsa C, Meriva (Zaragoza): ...54 221 944 28.02.2005 Corsa C (Eisenach): ...56 071 222 28.02.2005 Agila (Gliwice): ...5G 070 084 28.02.2005
    Remedy:
    In case of customer complaint the radio has to be replaced by a modified device with a new designed "CD-In-Recognition" switch. New parts can be recognized on the manufacturing date on the housing. From CW 04/2005 on (FD 0405 on the label) the radios are equipped with a modified CD drive.
    Note: Radios produced after mentioned breakpoint will not be accepted at radio-supplier and will be sent back to the dealer immediately.
    FunctionalGroup:N - Electrical EquipmentComplaint Group:13 - No/Poor FunctionTrouble Code: __________________
    if it is one of these try leaving a cd in all the time its a bodge but it stops the radio turning on on its own on the Vauxhalls with this problem.I had mine changed at two years old as it was a know fault to Vauxhall
    see here
    http://www.astraownersclub.com/vb/showthread.php?t=235520
  5. betterthenatent
    betterthenatent Read Only Funster
    Aug 23, 2010
    38
    We have an Autoquest 200 on a Peugeot. And today had the same problem. Did you manage to sort yours out.
  6. AdgeRas
    Sep 17, 2009
    495
    9
    Bristol
    Neither of us can remember if we did anything but we do know that we do not have the problem anymore.
    Hope you get your problem solved :Smile:
    Rasmus
