Flexible solar panels
Discussion in 'Solar Power' started by bubble63, Jan 26, 2016.
  1. bubble63
    bubble63 Funster
    Aug 10, 2012
    533
    472
    cambridge
    I have a smal folding Gobur caravan which we occasionally use for guests, its easy to tow and it takes up no room.:)
    When folded down, the roof is below eye level so i would like it to be neat
    It has a 75 ah battery and a slight curved roof
    It has led lights and a lcd telly
    I would like to fit a solar panel on the roof and have found this one
    http://www.ebay.co.uk/itm/100W-Semi...663993?hash=item4635d1f939:g:~RUAAOSw3ydVu56m
    Question, has anyone fitted a flexible panel and if so how did it perform, secondly how did you attach it
    I know the lack of air gap is a small issue but I have over specified the panel to make up for the loss, i think
    ta
  2. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,573
    5,641
    West Sussex
    Several posts on this forum about them failing in under 2 years, we also know someone who had one fail at 18 months old.
    • Like Like x 1
  3. seanoo
    seanoo Funster
    Nov 14, 2009
    360
    215
    normandy
    A friend of mine has a chandlery shop and he sold quite a few of these to boat owners. The general consensus was that they underperformed by quite a large margin. Don't underestimate the air gap below a solar panel, it is very important
    • Like Like x 3
  4. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,573
    5,641
    West Sussex
    Hardly surprising the way boat owners fit them.:D
    Saw this in France last year.
    • Like Like x 2
  5. hilldweller
    Dec 5, 2008
    26,909
    25,761
    Macclesfield
    The air gap is only for cooling, if the roof conducts the heat away you are on a winner.
    Anyway, what have you got to loose, £100, give it a go.
    • Like Like x 1
  6. horshamjack
    horshamjack Funster
    Apr 23, 2014
    419
    539
    Southern Europe
    I got 2 x 100w fitted over the Luton on our van, fixed by silkaflex. Fitted em over 2 yrs ago and working a treat,
    • Like Like x 2
    • Informative Informative x 1
  7. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,052
    3,452
    walthamstow east london
    we stuck one on my sons pop top and so far no problemsabout 8 months ago just stuck down with sika type glue
    • Like Like x 1
  8. Boycie
    Boycie Funster
    Sep 25, 2012
    294
    541
    West Cornwall
    • Like Like x 1
    • Thanks Thanks x 1
  9. bubble63
    bubble63 Funster
    Aug 10, 2012
    533
    472
    cambridge
    thanks for all the replies
    By coincidence the above post is exactly what I have singled out :)
    • Like Like x 1
  10. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,272
    10,770
    E Yorks
    We picked a new cheap 60w one at a show last year and I fitted it to our new PVC using some Sikaflex - the most taxing part was drilling the hole through the metal roof in the correct place for the cable ... thankfully after a lot of measuring and checking, checking and checking another few times, I got it right first time ... phew!
    If we hadn't got it already (we bought it before we knew we were changing PVCs!) I might have just gone for a standard rigid one but I must say that it was very easy to fit the panel itself as I just did 'squiggles' on the raised roof ridges and around the edge of the panel and pressed it on ... the hardest part was cleaning off all the ruddy Sikaflex that had got everywhere (don't ask!) which took much longer than the actual panel fitting!!! :D
    The panel on our previous PVC was an Alden 75w one which worked great (we wild camp or use aires all the time) so I was a bit concerned in case the smaller panel wasn't adequate, but it performed faultlessly when we had 6 weeks away so we're very pleased with it. If needs be I'll just add another one in the future but doubt if I'll find the need.
    • Informative Informative x 2
  11. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,052
    3,452
    for anything like sike and silicon you need to use big wipes from any builders merchants or poofix places or use baby wipes to clean up
    • Like Like x 2
  12. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,953
    2,749
    Englishman in Mid Wales
    Cannot vouch for other brands but do not buy the Biard ones as my two failed at about 18 months:cry:
  13. chaser
    chaser Funster
    Feb 16, 2013
    7,313
    8,015
    uttoxeter
  14. bubble63
    bubble63 Funster
    Aug 10, 2012
    533
    472
    cambridge
    Mines sat in the garage awaiting fitting
    Going to use Sikaflex and a terminal box , bonded to the roof
    I bought a 100w for £96 delivered , the white one that comes up on eBay
    I already have a 'steca' controller from my motor home when I fitted a mppt upgrade
    Just been on eBay and you can get a mppt for around £25 ,anybody used one ?
  15. Kevan
    Kevan Funster Life Member
    Jan 18, 2014
    518
    449
    Herne Bay
    the panel you show here are fine they are wired from the back, but as wizzer59 says don't by a BIARD they are wired at the font and are crap(y)
  16. tonyidle
    tonyidle Funster
    Aug 6, 2013
    2,967
    2,799
    Kendal, Cumbria
    .......................... and 2" masking tape exactly on the panel outline (y).
    • Like Like x 1
