Flexible solar panels.
Discussion in 'Solar Power' started by Robert 314, Oct 23, 2015.
  1. Robert 314
    Robert 314 Funster
    Oct 15, 2015
    47
    33
    Taunton. Somerset.
    Has anyone got any experience or advice on flexible solar panels as the motorhome has limited roofspace?
  2. premiere99
    premiere99 Funster
    Aug 7, 2013
    72
    31
    Medomsley, County Durham
    • Like Like x 1
    • Thanks Thanks x 1
  3. chaser
    chaser Funster
    Feb 16, 2013
    7,313
    8,012
    uttoxeter
    Does this post mean biard are no use, as was thinking of getting one.?
  4. premiere99
    premiere99 Funster
    Aug 7, 2013
    72
    31
    Fitted the first one and very happy, decided after 10 months to fit a second and then about 2 months later the first one died so decided to try a 150W from Renytek (they don't sell it anymore) which has a white backing instead of the Biard aluminium backing. Then the second Biard died after 14 months so after that failure I decided to get a normal panel and put that over the dead panel. I now have 290W, 140W rigid and 150W semi, the rigid gives a lot more output than the semi even though it has 10W less.
  5. Ranger
    Ranger Funster
    Nov 2, 2008
    225
    191
    Lincolnshire
    Our Biard lasted about 15 months so replaced it with a Lensun, time will tell.
  6. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,107
    14,921
    Leeds the one up North
    Presumably you mean you have limited FLAT roof space?
  7. sammy666
    sammy666 Funster
    Oct 10, 2011
    31
    11
    lincoln, lincolnshire
    it sounds like flexi solar panels are a waste of time and maybe the road pro was right in that the cheap ones are rubbish.
    So I am none the wiser really, ah well might be new developments in the future.
  8. mick noe
    mick noe Funster
    Apr 14, 2009
    615
    520
    near Boston Lincolnshire
    just stuck two 100w baird flexi panels to the roof seem ok.................time will tell!
  9. Anthea M
    Anthea M Funster
    Oct 18, 2015
    4,809
    13,637
    Sheffield
    Try @Triple7 he had them on his van when travelling.
  10. Lorryman100
    Lorryman100 Funster Life Member
    Nov 29, 2015
    261
    472
    UK/Scotland
    • Like Like x 1
  11. Triple7
    Triple7 Funster
    Sep 24, 2015
    211
    122
    Devon
    I use a flexible panel which is not fixed. Lots of advantages to outweigh the obvious disadvantage. Positioning, cleaning, replacing. It stores under the sofa cushion. Might be a good option if space is limited.
  12. sammy666
    sammy666 Funster
    Oct 10, 2011
    31
    11
    TRIPLE 7
    as a non fixed panel how do you get the power to the batteries, daft question I know but I am clueless on these matters.
  13. Triple7
    Triple7 Funster
    Sep 24, 2015
    211
    122
    Devon
    I have the cable from the solar controller coiled with a Velcro tab under the passenger seat. I feed it out through the side window and the connectors just clip together. I stand in the doorway and slip the panel on the roof, prop it up against one of the front tyres or place it on the windscreen depending on where the sun is. All very easy and by not having it out 100% of the time it needs a lot less cleaning (and is much easier).
  14. hilldweller
    Dec 5, 2008
    26,909
    25,760
    Macclesfield
    Look at the millions you see in solar farms, I've never seen stick on.
    • Informative Informative x 1
  15. The Lobster
    The Lobster Funster
    Aug 13, 2011
    80
    22
    Borders of Scotland
    I'm considering flexi-panels because they are much lighter and low profile (3mm) - so that I can feasibly put them on the overcab roof, either side of the roof light vent, rather than taking up space on the main part of the roof further back. Has anyone tried this?
  16. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,953
    2,749
    Englishman in Mid Wales
    • Like Like x 1
  17. Ranger
    Ranger Funster
    Nov 2, 2008
    225
    191
    Lincolnshire
    Our Lensun panel is still going strong and seems to deliver more current in poor sunlight conditions than the previous panels did which is good for the UK.
  18. Leish
    Leish Read Only Funster
    Sep 21, 2016
    3
    London
    Is it a 100W panel?
  19. The Lobster
    The Lobster Funster
    Aug 13, 2011
    80
    22
    Borders of Scotland
    Very interested in the Friendly Green Giant flexible panels - they claim to use the latest back contact method and "flatter" connecting boxes - but the price @ £0.87/W for monocrystalline panels is fab! Are you using the fixing kit they sell, or have you stuck the panels direct to the roof? If you're using the kit, how are you finding it - do you get any wind/flex underneath the panel, as it looks like they're slightly raised up by the fixing kit?
  20. wizzer59
    wizzer59 Funster
    Apr 18, 2009
    2,953
    2,749
    No the fixing kit looked a little bulky to me and even if it wasn't the panels are fitted at the front of my roof and like you I thought that the panel would get air under it as I travelled along and it might flap about and damage it, obviously I had some previous experience fitting and removing the Baird panels so quite happy to stick straight onto the roof(y)
