Flexible Battery cable diameter for 2nd battery? (1 Viewer)
Camping Gaza
993
1,467
La Châtre, Centre-Val de Loire France
Coachbuilt Low profile
Converted a Fiat Ducato PV a while back
Been searching on here can't find....
Adding a second 110ah battery... what diameter cable required? I know biggest is best, just trying to add capacity to existing 110ah not inverter etc. I dont know what the existing size is so anyone know an average?
Cross section or amperage would be very helpful. ie 25mm sq or 170amps
Anyone know?
Aug 6, 2013
11,953
16,568
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
10 or 12sq mm will be fine if the batteries are within a metre of each other. Cable sizing for low voltage D C wiring is based more on volt drop at required current than on safe capacity.
Al1
49
19
OD of 25mm2 cable is 10mm if that helps (170A), that's what I used to join two batteries.
Al
scotjimland
2,302
9,960
A Woosh bang
As said by @tonyidle
Buy 10 sq mm made up battery leads here.. various lengths and terminal sizes.. handy if you don't have the proper crimping tool
Note ..
cable is sized in cross sectional area .. ie ... sq mm ..
it is not sized by outside diameter
Aug 6, 2013
11,953
16,568
Kendal, Cumbria
since 1999
Must be a few. I'm not active but I put the call sign on to fish out the hidden ones. It hasn't worked very well☺. There's a thread somewhere about it.
Jaws
23,836
72,443
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
When wiring in extra batteries you only really need use wire capable of handling the absolute maximum you are going to draw and charge at..
If you do not use an inverter then something like AWG 8 or 10 would be right
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
A very high proportion of readers still would have no concept of what that is size wise, at least with mm they have a clue :LOL:
